94' 351W - How long will it last?
Old 09-01-2009, 01:36 PM
Cowboy Fleet
Cowboy Fleet is offline
Cowboy Fleet is starting off with a positive reputation.
My trusty old F150 (4x4 SC 351W Auto 3.55) is getting ready to hit 200K miles and I've never touched it except for tune ups and oil changes. It's down of power from when it was new but still running strong and does not burn any oil (does leak a little though). The truck has not been modified and I've not towed anything over about 2K lbs in years.
What do you think the upper end of miles I might get out of her? What's the weak link with these engines that forces a rebuild?
Old 09-01-2009, 02:36 PM
andym's Avatar
andym
andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
No weak link that I'm aware of. There is a user on here with over 500k on his 351, so anything is possible. There is a lot of luck involved with how long a motor lasts. If you get 200k out of one, I'd say that's about average.
Old 09-01-2009, 03:20 PM
Virto's Avatar
Virto
Virto is offline
Virto has a good reputation on FTE.Virto has a good reputation on FTE.Virto has a good reputation on FTE.
Lots of short trips will typically cut an engine's lifespan.
Keep up on the maintenence and you could see thousands upon thousands more miles. Where is your oil leak? Might be an easy fix.
Old 09-01-2009, 03:45 PM
Cowboy Fleet
I do a lot of short trips too as well as highway use on weekends. It's my only vehicle and has been since I got her in 96. I'm pretty **** about maintenance and have never missed an oil change interval by more than a few hundred miles. I've mostly used Mobil 1 with a high quality filter too so that cannot hurt.
The oil leak looks like it could leaking around the oil pan gasket seal, possibly the rear main seal. Hard to tell for sure but the top 1/2 of the engine is clean and oil free. When I change the oil I can always see engine oil on the trans bell housing and the outside of the oil pan is oil covered. It's not that bad so i've just let her mark her her spot on the driveway and not worry about it. One of these days though I should take care of it as it will only get worse. Is there a common oil leak area that I should look at to narrow down the problem?
500K out of this engine That's how I'd feel about that!
Old 11-27-2009, 08:38 PM
4x4truckdriver
4x4truckdriver is offline
4x4truckdriver is starting off with a positive reputation.
My truck is leaking at the rear main seal. I also had a leak at the dip stick tube. You might want to check that as well.
Old 11-27-2009, 09:07 PM
nextalcupfan's Avatar
nextalcupfan
nextalcupfan is offline
nextalcupfan is starting off with a positive reputation.
u may want to check the timing chain.
unless 5.8's use gears for timeing
most 302 timeing chains only last 100k to 150k but the 351 is a stronger motor
Old 11-28-2009, 07:35 AM
4x4truckdriver
My truck is heavily rusted from sitting, and the dipstick tube was pretty much gone when I got it. Just replaced it yesterday and there are no more leaks from the tube, however mine continues to leak at the rear seal area like yours. I saw on the web Bar's Leak stop. I am not a big fan of leak stop stuff, but that is an option for you. Dropping the pan, pump etc and/or pulling the trany is a big job. Let me know what comes of it?
Old 11-28-2009, 07:57 AM
andyman7931's Avatar
andyman7931
andyman7931 is offline
andyman7931 is starting off with a positive reputation.
My 351 bit the dust with the odometer reading 52k. I have to assume that it was 152k because the age of the truck and the fact that the interior is in great shape. My truck was worked by the previous owner, so it may have shortened the life of it some. The failure on my engine was low oil pressure. I'd invest in an aftermarket gauge so you could have warning before it drops too low. You could repair cheaper parts instead of a complete rebuild if you catch low oil pressure early.
Oreilly auto parts was kind enough to give me a remanufactured engine in exchange for $1100. I hope to only get 100k out of this one since I only use my truck for hauling lots of weight, but at 4k miles a year, that's fine with me.
Old 11-28-2009, 08:03 AM
Linemo
Linemo is offline
Linemo is starting off with a positive reputation.
Mine has 312,000 and still runs great so they will last the timing chain on the 351's are double roller chain and they are much stronger than earlier models
Old 11-28-2009, 08:10 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
My 302 has 275k miles on it and still runs great. The 4R70W transmission is original also.
Old 11-28-2009, 08:11 AM
Nitramjr's Avatar
Nitramjr
Nitramjr is offline
Nitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant future
You oil leak could be from a hole in the pan like mine is. One day I will have to address it correctly but for now it is the occasional sanding and JB Weld. That and watch the oil level.
Old 11-28-2009, 08:38 AM
4x4truckdriver
Sorry about your loss. My truck was abused also, my oil was sludged up and it took 3 cleanings to get some of the junk out. My pump screen was clogged...
Old 11-28-2009, 09:17 AM
rikard's Avatar
rikard
rikard is offline
rikard is gaining momentum as a positive member of FTE.
My 95 300 has 204k on it and it runs great. I plan to put another 100k on it. My Dads 83 302 AOD went 220k with its original power train still in good condition. I did have to change out the valve cover gaskets and front timing cover seal at about 140k. The truck had oil changed @ 4k and the tranny oil changed annually. The coolant, PS fluid, and rear axle oil were changed every two years. I even flushed the brake system at 100k. Other than some electronic ignition issues the truck was very reliable. The reason I have a Ford truck today is because of that truck. Frame
rust was the reason I had to get rid of that truck and I needed a van at the time.
Personal record was a 305 chevy that hit 250k and was still going when I lost track.
BTW my son used to work for a transmission parts company and many of the Aerostars and Astros had well over 300k. The sales area covered most of southern NE and the trucks were very abused. Oil was changed once a month.
YMMV
rikrd
Old 11-28-2009, 09:40 AM
BCHauler's Avatar
BCHauler
BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
My 94 351 had 420k+ kilometers when I damaged the bottom end pushing her too hard up a mountain pass. Thats 250k+ in miles. My trucks history is mostly unknown but had sat for a couple of years before I got my hands on it.
patrickj20
07-31-2017 09:07 PM
1994 F150 2x4
1997 - 2003 F150
04-28-2017 08:28 PM
boomer1ny
15
12-13-2013 10:20 PM
JLD
30
07-22-2002 03:31 PM
gbashjr
07-20-2001 05:40 PM
Quick Reply: 94' 351W - How long will it last?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
