Tachometer
Old Jul 5, 2015 | 07:52 PM
bbierschenk's Avatar
bbierschenk
Tachometer
I'm thinking about buying a tachometer for my 1979 f150. I would like to know good brands and how I would install the tachometer on my truck.
Old Jul 5, 2015 | 08:30 PM
HIO Silver's Avatar
HIO Silver
What's your budget?
Higher end... Autometer
Decent... Sun SuperTach II or III
Lowbuck... SunPro
Visit a car show/swap meet and search for gold
Four wires:
Black - ground
Green -tach signal
Red - Switched power
Blue - instrument lighting
Old Jul 5, 2015 | 08:40 PM
bbierschenk
I don't think I want to pay anything over 60-70 bucks, and thanks for the help.
Old Jul 5, 2015 | 08:42 PM
HIO Silver's Avatar
HIO Silver
Sun SuperTachs are around $45 from Autozone.
Follow the directions to install.
Old Jul 5, 2015 | 08:46 PM
bbierschenk
Sounds good, that's probably what I'll go with. Thanks again for the help.
Old Jul 6, 2015 | 02:32 AM
burnthelight88's Avatar
burnthelight88
For mine, instead of hooking the switched power wire to the ignition and the instrument lighting wire to my actual light switch which I understand can be a pain, I hooked them both to a yellow connector under the dash. If you look up underneath there between the driver's kick panel and steering column you should see it. Its bright yellow and has three ports (you can use any of the 3). The connector is only hot in the run position and accepts male bullet crimp connectors very easily. It definitely saved me a lot of time. The only downside, which I don't consider a downside at all, is that the tach backlighting is always on. I can't tell at all during the day, and its on at night when I need it to be. Saved me a lot of time tearing into the headlight switch or molesting any other existing wiring.
Old Jul 7, 2015 | 06:59 PM
bbierschenk
Yeah that sounds a lot easier than tearing into the switch, I'll have to look for that connecter tomorrow. Thanks for the idea.
Old Jul 7, 2015 | 07:17 PM
dustyroad's Avatar
dustyroad
Closest I found for that connector was at Napa, it isn't an exact fit but it will work. It will be snug though. It's a .156 bullet or something like that. I threw away the marking on my box.
Napa was the only one close to me that had it in stock without ordering online may be different in your woods.
Old Jul 7, 2015 | 07:54 PM
HIO Silver's Avatar
HIO Silver
If yallz are interested in installing a low-buck, quick disconnect for your tachometer, use a 4-pin male and female trailer wiring harness
Old Jul 7, 2015 | 09:10 PM
bbierschenk
I think my dad might actually have one that size in in his box of connectors and splices.
Old Jul 7, 2015 | 09:12 PM
bbierschenk
You should patent that idea or something lol, I might try that too.
clhart426
Oct 17, 2009 09:14 PM
tx64f100tx
Nov 27, 2007 09:08 AM
Tuvanhillbilly
Jan 14, 2004 12:02 AM
Andysutt
Electrical Systems/Wiring
Jul 10, 2003 08:26 PM
mudbug
Jan 7, 2001 01:50 AM
