Chop saw
Old Jul 5, 2015 | 05:49 PM
johnfin1's Avatar
johnfin1
Chop saw
Is it possible to turn a 10" wood miter saw into a steel tubing chop saw. ie just a blade replacement?
Old Jul 5, 2015 | 05:55 PM
drptop70ss's Avatar
drptop70ss
My metal chop saw uses 14" blades, plus the RPM on the wood saw may not match up with the metal blade. I would get a cheap harbor freight metal chop saw before trying it.
Old Jul 5, 2015 | 05:57 PM
49willard's Avatar
49willard
That is what I did to do my ss exhaust and it worked well
Old Jul 5, 2015 | 08:36 PM
drptop70ss's Avatar
drptop70ss
You have more guts than me My metal chop saw is built like a tank compared to my dewalt wood saw.
Old Jul 5, 2015 | 09:42 PM
iwanaflattie's Avatar
iwanaflattie
Worked for me.
Old Jul 5, 2015 | 09:44 PM
Okiedokie's Avatar
Okiedokie
I have a metal blade for my skill saw, have used it many times, works great.
Old Jul 6, 2015 | 12:59 AM
CharlieLed's Avatar
CharlieLed
I have used metal cutting blades in my chop saw for years. The only issue that you may have is in the blade guard/sawdust collector. The first one I used had a plastic tube that melted when the hot metal chips came in contact with it. I did break down and buy a Makita circular saw that is built specifically for metal...nothing melting and the rate of rotation is correct for metal.
Old Jul 6, 2015 | 09:49 AM
lowtrkn2k's Avatar
lowtrkn2k
Go get a cheap HF chop saw. I tried that with my skill saw and it didn't work very well. It may be ok on thinner tubing but anything thick it will be difficult, or at least that was my experience. It only costs some time and a cutting wheel so try it out but my HF heavy duty chop saw has worked well for a few years now and it cost me less than a $100 with a coupon. Definitely well worth the cost.
Old Jul 6, 2015 | 01:23 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Just use an abrasive cutting wheel, not a metal tooth one, and you will be fine. If you are going to do a lot of metal cutting do as suggested and buy a cheap HF one (or some other chinese brand).
Old Jul 6, 2015 | 02:01 PM
gerrymoe's Avatar
gerrymoe
IMO anytime you use a tool for any other purposes than what the tool was intended for there is a risk involved whether it be injury or premature wear down of the tool. My rule of thumb is once twice OK but anymore I buy the correct tool for the job
Old Jul 6, 2015 | 02:55 PM
oldmerc's Avatar
oldmerc
oldmerc
I removed the plastic parts off a spare 12" Dewalt chop . Works well enough for for the amount I need
grinnergetter
Garage & Workshop
Mar 4, 2014 08:29 PM
mrc59
Garage & Workshop
15
Mar 3, 2009 05:47 PM
66 twin i
Garage & Workshop
Nov 26, 2006 06:43 PM
Steve_B
Garage & Workshop
Apr 3, 2006 11:06 AM
sparky30_06
Garage & Workshop
Apr 7, 2005 03:12 PM
