Bandsaw or Chopsaw
I am planning on buying a saw for cutting Stainless and Mild Steel Exhaust tubing, bar stock and box section
I am considering a low cost band saw like this http://www.machinemart.co.uk/product.asp?p=060710025
A abrasive wheel chop saw like this
http://www.machinemart.co.uk/product.asp?p=060110871
Or a TCT bladed chop saw like this
http://www.machinemart.co.uk/product.asp?p=060110873
I would appreciate opinions on the pro's and cons of these saws
Steve
I actually use a Porter Compound Miter saw with a metal cutting blade, with a shop vac attached to the exhaust port, with a few homemade "spark directors" I added to the saw housing. This way the hot metal sparts don't collect on the lasers and wiring inside the saw housing, and most of the sparks go out the exhaust port into the shop vac.
The reason why I prefered this solution over an official chop saw was simple - I've yet to find a chop saw that I can afford, that can do compound miters.
I also have a bandsaw, but I generally don't use it for cutting round tubing. Sometimes I'll feed it flat stock, bar stock, or square tubing, if the cuts are straight. Anything mitered I prefer to use the chop saw.
+ inexpensive to buy
+ blades are cheap and widely available
+ fairly fast cutting
+ will cut up to about 1/4 inch steel (in any shape that will fit)
+ easy to set up
Abrasive chop saw cons:
- the blades wear down quickly
- the grindings make a mess
- extremely loud; throws metal and sparks
- always wear ear and eye protection
- possible fire hazards
Metal band saw pros:
+ Cuts heavier material than the others
+ relatively quiet
+ Less messy than chop saw
+ not as loud as chop saw
+ minimal sparks/fire hazard
Metal band saw cons
- Blades are more expensive
- More work to set up
- Needs cooling oil for good blade life
- relatively slow cutting
TCT Bladed chop saw pros
+ Easy to set up
+ Not as messy as abrasive saw
TCT Bladed chop saw cons
- Saw is more expensive to buy
- Blades are much more expensive than the other two
- Blades harder to find
I personally have an abrasive chop saw. It works well, but it is one of those tools that I tend to hate to use, just because it is so loud and dirty, especially on thicker material. For stuff like thinwall tubing, the noise and mess isn't so bad, and it cuts almost as fast as the equivalent wood chop saw
A band saw augments a chop saw fairly nicely, as it is more suitable for thicker stock. This may be my next metal working tool purchase. I don't see why I would want a TCT saw; but that's my personal bias.
Steve
Andrew
Cheap hotsaws are flimsy, -look at the rigidity of the base!
Space is a issue (small workshop), noise may be a issue in the future (new larger shop with closer neighbours) so the TCT chop saw looks like the best solution for now, may get a bandsaw in the future.
Thanks again
Steve
P.S
Andrew, I see you are in the UK, have you got a truck?, Whereabouts are you?
I have a 54 F100 and live in West London near Heathrow Airport
Thanks again
Steve
P.S
I'm in Beckenham Kent. I haven't got a truck yet
. My wife is from Atlanta GA so i got the Ford Truck interest from my visits over there. I anticipate buying an F250 if and when we move over there
