Sponsored by: Real Truck
2008 Integrated brake controller problems
Old Jul 5, 2015 | 02:24 PM
Slackdaddy's Avatar
Slackdaddy
2008 F350.
sitting in the driveway: gain set to 10, when I squeeze the manual "levers" together the graph display completely lights up and I get 12+ volts at the trailer plug.
When I press the brake pedal I get a full graph display but only 2 volts.
Hooked up to the trailer, pushing the pedal gives very very little braking (I can turn the hub by hand),
Squeezing the manual levers the drums lock up.
Is normal? is the controller faulty ??
Nick
Old Jul 5, 2015 | 04:58 PM
Slackdaddy's Avatar
Slackdaddy
Update:
I opened the J box on the trailer, ran a 12ga wire from the brake wire, into the cab of the truck and hooked it to a DVM.
I set the gain to 8.0
at a standstill with the brake pedal floored I got .5V
at 20mph coming to a brisk stop I got 2-3 volts,
at 30-40mph coming to a brisk stop I got 4-5 volts
at 50mph I got 6-7 volts.
squeezing the manual brakes I got 10.5v at a stand still
Slack
Old Jul 5, 2015 | 06:32 PM
sxrfun's Avatar
sxrfun
The integrated brake controllers on these trucks determine their output on a # of factors.....what you have the gain set at, what speed you're doing, and how hard you're pressing the brake pedal. I'd say your findings are normal for being stopped in your original tests.
Old Jul 5, 2015 | 08:20 PM
RV_Tech's Avatar
RV_Tech
This is an ongoing complaint with the Ford TBC. it is perhaps the most misunderstood component ever developed. From your numbers I think your controller is working correctly. What it does at manual versus the pedal is irrelevant.
Steve
Wildcat313RE
6.7L Power Stroke Diesel
Apr 2, 2017 04:20 PM
rusbukt
All Things Towing
Jan 31, 2016 06:35 PM
firewood truck
Jul 8, 2012 12:28 PM
ultramag
May 15, 2009 09:30 PM
ron9florida
Mar 24, 2007 12:45 PM
