I am building a 84 F150. I picked up a set of doors off of a 92 with nice door panels that I would like to use. I also replaced the dash but need to change the color of it. Would anyone know the available colors of interior in 92. It is a tanish color. I could not look at the door sticker because it was just the doors when I picked them up.
Last I checked the 92-97 door panels will Not work with the 80-86 dash. Up by the wing window you will notice the 92-97 door panels stick out more than the 80-86 door panels. They will get smashed against the dash if you try and use them
I have updated the dash to work with those doors. But the dash is the wrong color. This is why I'm trying to find out color options so I can get some SEM paint to match the dash to the door panel color.
I already have all of those issues taken care of. This truck was done from ground up. Not needing the newer wire harness. 418 stroker clevor and carbureted, zf 5 sp. Have pedal assembly taken care of along with the column. Just needing to know what interior color options were available so I can try to match this dash.
