I need to replace the shift collar on the sterring column of my 4X4 78 F150, 351M, Auto trans. Looks like a straight forward job, any hidden problems? Just pull the wheel and then remove the collar right? Do I need more than the collar and the shifter pin?
On those two bolts, you don't need to remove the nuts completely to get the collar off - just loosen them but leave the nuts started until it's out of the truck so you can't drop them.
I replaced the collar and put everything back together and now the truck wont start in any gear. I can put in the gears and all the lights work fine. Any thought on what could be the problem?
What year? and automatic?
If its 73-77, check the neutral start switch. It's mounted on the steering column, under the dash, on top near the firewall. To check, hold the key in the "start" position and slowly move the gearshift from "park" position towards drive. If it tries to start, the switch is out of adjustment.
what are they doing anyway,I can't figure out what are they attache to
They hold the steering column flange to the steering column. There are a couple of slots the square heads engage.
This is probably the "trickiest" part of reassembling a steering column.
Here is a youtube video on the reassembly. It's part three and is for an early Bronco but the process is the same.
Here is a youtube video on the reassembly. It's part three and is for an early Bronco but the process is the same.]
thank you so much mike i got it now ,the t bolts grab the 2 holes in the tube okay i got the missing piece why my steering shaft was still loose ,i took it apart like the software said but the software only tells me how to take it appart put it back together it said reverse step 1 to 17 ha ha clever how did i know whats behind the collar
I am back on the road. I had to tweak the bead on top a little, but after some struggle getting things together I am driving again. Thank you so very much for your insight and sharing your knowledge.
I think you grabbed the wrong thread but it's good to know you're back on the road.
