Reverse eye main leaf
Old Jul 1, 2015 | 08:40 PM
Mitch1129's Avatar
Mitch1129
Soooo I'm looking to drop the rear end of my 52 F1. I have the posies drop leafs all the way around. How much would I drop roughly in the rear if I put a reverse eye rear main leaf?
Old Jul 2, 2015 | 09:47 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Depends on the manufacturer. If your staying with posies I'd give them a call. They should know exactly what it would take to drop your trucks rear stance the amount you want.
Old Jul 2, 2015 | 10:31 AM
ALBUQ F-1's Avatar
ALBUQ F-1
How much clearance between the axle tubes and the frame as it sits?
Old Jul 2, 2015 | 11:33 AM
gerrymoe's Avatar
gerrymoe
Just checked the posies site on the 48-64 ford truck front and rear lower springs page 39, the picture shows the main leaf already has reversed eyes.
On reversed eyes the eye is below the arch and on stock the eye is above the arch if that explains it clear.
You could use the dual flex mono spring which posies states is safer than just the mono.
http://www.posiesrodsandcustoms.com/...OOF-4-4-14.pdf
Old Jul 2, 2015 | 09:32 PM
Mitch1129's Avatar
Mitch1129
I'll check that out tomorrow Gerry. Just got home from work. Racking my brain how to drop this rear 2"'s.
Old Jul 2, 2015 | 09:33 PM
Mitch1129's Avatar
Mitch1129
Albuquerque I'll have to measure. Truck is at the garage getting worked on.
Nitro1168
May 23, 2018 05:40 AM
hooverdammatt
Mar 14, 2007 09:58 AM
460
Offroad & 4x4
Aug 27, 2006 10:00 AM
49willard
Jan 16, 2006 07:27 PM
54at50
Sep 5, 2004 07:29 AM
