oil consumption
Old Jul 1, 2015 | 05:43 PM
06lariat's Avatar
06lariat
Question oil consumption
I've got an 06 F-150 5.4, uses over a quart of oil between oil changes at5k mi. I get a cloud of blue smoke at start up. Truck has 53k mi. Anyone have a similar problem.
Old Jul 2, 2015 | 08:46 AM
1saxman's Avatar
1saxman
No, but it sounds like the oil is getting into the cylinders from the heads. This used to point to valve seals on pushrod engines but I'm not up on how things are done in the new mills. About 1 qt in 5000 miles is actually not considered serious oil use, but most of these engines do not use oil.
Old Jul 8, 2015 | 03:02 PM
whimsey's Avatar
whimsey
Make sure your PCV valve and hoses are not clogged and working. Though 1 quart in 5,000 miles is not bad. Also some oils will be used in the engine more than others. Sometimes when changing oil brands and type you can tend to use some oil at first but it usually stops. I've had this when first using Mobil 1 and Havoline synthetic after using other oils.
Whimsey
Powerstoke73
19
Nov 2, 2021 07:13 AM
Brian 2002
Aug 6, 2007 06:09 PM
EaTmYtAiLpIpEs
Jul 31, 2007 10:01 PM
Mike-G
1997 - 2003 F150
May 17, 2007 10:12 PM
2fords2
Oil & Lubrication
50
Feb 13, 2004 10:12 PM
