Suspension noise
Old Jul 26, 2015 | 09:45 PM
RACERX7775's Avatar
RACERX7775
I just did the same thing last week. New XRF ball joints, new hubs, new sway bar links. Still making the clunking noise. Does anyone know of what the size of the sway bar is for the bushings? Thanks. I'm ready to drive this thing off a cliff.
Old Jul 27, 2015 | 01:43 AM
R&T Babich's Avatar
R&T Babich
We recently purchased a 2002 2wd V10 100k and also have a clunking feel/noise in the front end right under your feet. It happens more often when going thru dips in a turn. At first I thought it was radius arm bushings (we have 3 1st gen Explorers), but after dropping them to take a look they seem fine. I have already replaced the shocks and installed a Hellwig front sway bar which came with new main bushings, the end links look fine. I tried twisting the steering linkage, it was stiff and not smoothly rotating the joints. After greasing the joints they twist better, but still have rough spots. Will test drive over the next few days.
Old Jul 27, 2015 | 06:40 AM
wpnaes's Avatar
wpnaes
Disconnect the front anti-sway bar and drive it like that for a while. I do this during off road trips for the extra suspension travel. See how it feels to you on the road. That will confirm the 'sway bar' source of noise. The bar will droop down, but won't be in the way as you drive.
Old Jul 28, 2015 | 07:46 PM
RACERX7775's Avatar
RACERX7775
Sean, wtf is up with that sway bar mount?
I had the wife jumping on the drivers running board and was able to see the sway bar moving and clunking. What size are the bushings?
Old Jul 28, 2015 | 08:52 PM
done12many2's Avatar
done12many2
I just used the Moog Sway Bar Bushing Kit from Advance Auto and greased them up good.
Part No. K80203
Very cheap fix, but like I said previously, I'm not sure if it was the end links or the bushings specifically because I replaced both at the same time. I'm just happy the noise is gone.
Old Jul 28, 2015 | 11:27 PM
wpnaes's Avatar
wpnaes
Back in 2008 during an off road Excursion, I did some remodeling down there. Some great memories looking back at the pics.
Broke the entire mount off with a boulder. Decided to upgrade to steel bar. No complaints since.
edit, found the video.
Old Jul 29, 2015 | 05:20 AM
agsmv1's Avatar
agsmv1
I used these Energy Suspension 4.5180G Front Sway Bar Bushing Set 16.xx at Amazon. Not sure if there is a difference in sway bars..as we have different years.
Old Jul 31, 2015 | 09:33 PM
kconrad's Avatar
kconrad
I finally found my noise. It was my front sway bar bushings. They were shot. I bought a new Hellwig bar and used existing end links. I now have a noise in a bushing somewhere up front.
Old Jul 31, 2015 | 10:09 PM
R&T Babich's Avatar
R&T Babich
What exactly was worn out? The metal sleeve, rubber missing,?
Any pics of the worn parts so we can see what to look for?
Old Aug 1, 2015 | 11:35 AM
RACERX7775's Avatar
RACERX7775
Just got the same kit yesterday. Sort of installed them. They are way to small. Either way, with a generous amount of grease, I drove it up the street. STILL HAVE THE CLUNK!!!!!!!!!!! If I rock the truck hard left to right, I can hear it. Just can't see it. Really starting to hate the truck.
jstihl
Dec 28, 2017 08:32 PM
CopperExpo
Jul 24, 2017 09:27 AM
EscapeeBob
Escape & Escape Hybrid
Apr 16, 2015 10:11 PM
stardotstar
2004 - 2008 F150
Jul 18, 2011 01:11 PM
pksignator
Apr 25, 2005 06:00 PM
