Noise Suspension
Old Jul 18, 2011 | 09:05 AM
stardotstar's Avatar
stardotstar
Noise Suspension
Just had new full struts installed as well as rear shocks on 04 F150, supercrew. There is a noise that only happens when you hit a bump. I initially thought it was sthe strut boot but having those replaced, and the noise still there means it was not that.
Anythoughts as to what I should look at sounds like something is loose on the front end. Had an alignment done and they said all was tight.
Thoughts to look at?
Thanks
Old Jul 18, 2011 | 09:22 AM
Coskid's Avatar
Coskid
May be your front sway bar links check out this thread from last week sounds like a similar problem.
https://www.ford-trucks.com/forums/1...ally-last.html
Old Jul 18, 2011 | 09:30 AM
stardotstar
Thanks, that sounds exactly like it. Now to find out if I can do this. Does this require a new front end alignment?
Old Jul 18, 2011 | 01:11 PM
Coskid's Avatar
Coskid
I am not sure if it requires an alignment afterward or not but I would be willing to bet you could do it yourself and then have someone align it for you afterward.
dfboothe
2004 - 2008 F150
Jul 7, 2012 04:36 PM
xFordGurl
Escape & Escape Hybrid
Oct 8, 2011 10:27 AM
69oiler
Sep 12, 2011 08:15 PM
BGreeson
Jun 21, 2010 01:02 PM
bbb1777
2004 - 2008 F150
Mar 3, 2005 11:46 AM
