97 F-250 460/7.5L e4od 4x4 lacks power up hills
Old body style.
It starts, idles, and runs fine but lacks power up hills.
I've checked the base timing, injectors, plugs, wires, fuel pressure, and all are good. I've looked all over for a vac leak.
If I disconnect the IAC (idle air control valve) the motor slows to around 750 rpm and the engine doesn't quit and it does not suck any air thru the black hose below the iac and The butterflies are fully closed, Doesn't this indicate a vacuum leak? Is the engine supposed to quit when the iac is disconnected? Is the IAC supposed to close when the engine is given throttle?
Sure you can... Depends on how fast you're going though. If you're turning anywhere above 2000 RPM a healthy 460 will climb most average hills like they aren't even there.... That's the upside to owning a torque monster....
Looks to me like you have a vacuum leak. The engine should idle in the 500 RPM range or stall with the IAC disconnected.
Have you checked for codes (KOEO & stored codes)?
When did this problem start? Any parts replaced previously?
Age/miles on the plugs,wires,cap,rotor and filter?
I just got the truck.
170,000 miles all the normal
stuff is newer. Plugs, wire, cap, rotor.
Fuel regulator checks out ok.
After cleaning the IAC it seems to adjust idle quicker when putting it into gear. It drops quite a bit when you disconnect IAC but does not die.
How new? Have you pulled the plugs to inspect them?
Please define "ok"
You previously stated with the IAC disconnected the idle RPM was 750. That's way too high. Inspect the throttle stop screw for signs of tampering. If that checks out then you have a vacuum leak somewhere.
Please define "ok"
When I tested the TPS unplugged with one lead on the center wire and the other lead on the left side I see full range or basically no glitches as I turn the TPS ****. like an ohm meter on a potentiometer. When I check the right side I see full range then it cuts out about 3/4 of they way thru the TPS rotation. Is that supposed to happen?
Some reference material of how the TPS operates: TPS
I always test the TPS voltage output. Test it with the Key On Engine Off.
Below is the most thorough and easy to understand video on TPS testing I've found. Being Half color blind is a pain.
Please define "ok"
Please define "ok"
I'll check it again. Plates look closed to me, the screw was barely doing anything, plates were at full rest/closed position. I am suspect of a vac leak but I've looked everywhere concerning a vac leak.
Fuel regulator vac hose was disconnected while I had the gauge hooked up and it ran up the pressure to within specs.
