Sponsored by: Real Truck
Need Torque Value
Old Jun 30, 2015 | 08:44 PM
340 Master's Avatar
340 Master
Need Torque Value
Does anyone know what torque value is in foot pounds that Ford recommends for the 10mm bolts that attach the overload spring bumper brackets to the frame on a 2014 F250?
Thanks
Old Jun 30, 2015 | 09:21 PM
Just Strokin's Avatar
Just Strokin
The service DVD doesn't show any value. I would assume that if you tightened it snugly and not over tight it would be ok. There is no movement of the bumper even when compressed.
Old Jul 1, 2015 | 09:39 AM
340 Master's Avatar
340 Master
Thanks Larry,
I would think Ford would specify a bolt torque value for the bolts that attach the frame mounted brackets that the auxiliary overload springs make contact with when the truck is loaded. On a truck that comes from the factory with overloads the front frame mounted bracket is riveted to the frame and the rear bracket is bolted. To add overload springs to a truck you have to bolt both front and rear brackets to the frame and I doubt Ford would not have a torque specified for that.
Thanks
Old Jul 1, 2015 | 12:29 PM
Just Strokin
I suspect the bolts used to attach these brackets are nothing special. The truck would still be functional even if one broke off or came loose. I would find the torque value for the size both used to attach them to the frame and use that value when mounting them.
Old Jul 3, 2015 | 03:49 PM
DavidB's Avatar
DavidB
Bolt torque chart:
Bolt Torque Chart - Portland Bolt
Old Jul 3, 2015 | 05:02 PM
Just Strokin
Originally Posted by DavidB
I suspect the bolts/nuts are metric. This chart has both metric and sae.
Bolt torque specs for socket head cap screws for machine repair assembly bolt torq CNC
super_duty_532
Jun 8, 2018 08:05 AM
carlsson
Feb 16, 2016 12:31 PM
thunderbirdcakes
Sep 12, 2013 05:48 PM
Franken-Truck
Jul 18, 2005 09:57 AM
NAA_Silent
Aug 24, 2003 01:07 PM
