Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2000 Lightning traction!? help
Old Jun 29, 2015 | 10:14 PM
rtreftz's Avatar
rtreftz
So I have a modified Lightning that gets no traction in first gear. I want to buy 2 wheels for DOT drag tires. What size wheels and what size tires? Thanks in advance.
Old Jul 1, 2015 | 06:55 PM
JEFFFAFA's Avatar
JEFFFAFA
Factory 2000 Lightning wheels were 18" X 9.5". 135MM bolt pattern. Could have M12 Or M14 lug stud holes. I'd buy some aftermarket wheels close to that. Tires? Depends. Right now is it going through the traps right in the middle of the engine's power band? If not adjust that a tad by buying tires with a little more or less "rolling distance". AKA O.D. www.miata.net has a real good tire size comparison tool. You can plug in your current tire size and plug in different sizes of the tires you want to buy and it will tell you the difference in width,height,rolling distance,etc. This is industry averages not particular brands.
Old Aug 14, 2015 | 04:42 PM
lukeharper's Avatar
lukeharper
Stock sizes are 18x9.5
clydesdale6
Jan 2, 2011 03:50 AM
pintoches
May 20, 2009 08:46 AM
fasthauler
May 26, 2007 01:29 AM
GAPW
Sep 26, 2006 09:58 AM
JWRapp
Aug 11, 2003 10:51 PM
