Rear Fuel Tank Guzzling
Old Jun 28, 2015 | 11:00 PM
Joshey93's Avatar
Joshey93
Question Rear Fuel Tank Guzzling
I drive a 1994 F250 with the 460 engine (7.5L) that has 2 fuel tanks. I just got back from a weekend trip and I noticed something weird on this trip. When using the front fuel tank, I was able to get almost 14mpg. When using the rear fuel tank, I was only getting around 5mpg. Anybody have any idea why this is happening or how I can deal with it?
Old Jun 28, 2015 | 11:16 PM
Mike1's Avatar
Mike1
Was the rear tank full when you switched it over? It sounds like the rear tank is leaking into the front tank.
Old Jun 28, 2015 | 11:19 PM
Joshey93's Avatar
Joshey93
I can empty the front tank and the rear will still say it is full. I don't thinknow it is leaking into the front tank.
Old Jun 29, 2015 | 07:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
the valves sometimes stick allowing return fuel to go to the wrong tank. this will make it seem as you are using twice as much fuel as you actually are using.
try this: fill the front tank when it is at 1/4 tank mark. run it back down to 1/4 and see if it takes about the same amount of fuel, around 12-13 gallons.
now run the front tank down to 1/4 again and switch over to the full rear tank and run it until it is empty.
fill the front tank and see how much fuel it will take to fill. i bet it will only take around 6-7 gallons.
this will tell you the unused fuel is returning to the front tank instead of the rear tank.
Old Jun 29, 2015 | 08:28 AM
Conanski's Avatar
Conanski
Yeah you have the fuel transfer problem. Run the front tank down a bit and take note of the fuel level, and then switch to the rear and run it for a while. Then switch back to the front and check the level, if it's more than when you first switched to the rear then the problem is confirmed.
Old Jun 30, 2015 | 08:11 PM
Sdowdle541's Avatar
Sdowdle541
What's the fix for this?
Old Jul 2, 2015 | 01:06 PM
tjc transport
i ain't rite
on the newer trucks it would be replacing the in tank fuel pump that has the bad valve in it.
on the older trucks it would be replacing the selector valve.
Old Jul 2, 2015 | 06:52 PM
Conanski's Avatar
Conanski
Yeah replace the Fuel Delivery Module(FDM) in your front tank, that contains the fuel pump and the check valves that are supposed to prevent crossflow between tanks.
Old Jul 3, 2015 | 09:11 AM
OFLM's Avatar
OFLM
I am having the same issue. Who makes the best FDM?
bullnose1985
43
Mar 26, 2024 03:13 PM
Hiddencamper53
Apr 16, 2016 05:59 AM
4EyedTurd
Dec 20, 2012 11:49 PM
cowmilker08
Mar 25, 2009 03:36 PM
scozim
Jun 11, 2006 12:14 AM
