Trying to Replace Inner Axle Seals
Old Jun 28, 2015 | 12:51 PM
jbs94's Avatar
jbs94
Hi guys. Im trying to replace my inner axle seals on my front diff. I've already pulled both the axle on both sides, and I've removed the differential cover as well as the two brackets that hold the carrier (I think that is what it is called). I know I have to get that carrier out in order to knock the seals out, but I can't get it to move. Am I forgetting something? This is the first time I've done any of this, so I'm learning as I go.
Old Jun 28, 2015 | 08:48 PM
Thomas White's Avatar
Thomas White
It has been EONS since I was in a front axle (like 10 - 15 years). I want to say the only thing that holds it in at this point is the Pinion Bearing.
Post back your vin I will look it up tomorrow when I get some free time.
Old Jun 28, 2015 | 11:36 PM
Baatzy's Avatar
Baatzy
It sounds like you have everything removed. When I did mine about a month ago it required a lot of prying to get it out. Just pry out a small amount at a time and it will eventually come. I forget how we got mine started but it was a pain.
Once you do get it out though, put it on ice, or in the freezer or whatever you can do to get it cold, otherwise you'll never get it back in.
Baatzy
Old Jun 28, 2015 | 11:48 PM
HD Rider's Avatar
HD Rider
What Baatzy said. Just pry it out. Keep the bearing cups on the correct side so they go back in where they were. Wrap the carrier in a plastic bag and put it in the freezer while you do all the other work. That will make installing it much easier.
enriched&beyound
24
Jun 12, 2017 07:15 PM
Darksideforge
1997 - 2003 F150
15
Mar 29, 2017 09:07 AM
ultraranger
18
Feb 22, 2016 03:27 PM
rpatrick
Aug 15, 2009 07:23 PM
brown 4x4
Sep 26, 2003 12:53 PM
