Sponsored by: Real Truck
OBD11 port location
Old Jun 27, 2015 | 01:02 PM
tangster's Avatar
tangster
OBD11 port location
As luck would have it I'm leaving out in the morn for 600 miles , Noticed a nail in my L/F tire yesterday went too Goodyear they pilled the tire patched it inside.. Then this morn went to fuel up my ABS light stayed on .. Did this last yr. went off after a few days but since the tire was pulled maybe its a bad connection ??? ..Jut want to be sure and scan codes
I want to scan it now to check and reset any codes But looked under the Drivers side dash can not find the OBD connection port looked on Passenger side nothing there either.. Looked under hood around fuse box did not see anything that kind of looked like a port with a cap I'd assume they cap them if under the hood .. Its a 05 S/D 6.0 any help helping me locate this OBD11 port would be appreciated .
.Thanks
Old Jun 27, 2015 | 01:19 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The ABS wire and sensor can get messed up if someone is careless removing or installing a tire, you might have to pull the tire and inspect the sensor and wire.
OBDII port is right here:
Old Jun 27, 2015 | 01:55 PM
tangster's Avatar
tangster
Thanks I found the OBD ran a scan said C1145 Rt. Front wheel speed sensor input control failure.. Its not the wheel they pulled yesterday I tried to reset codes but did not seem to want to erase .. It did this last summer a I recall it now hit some loose concrete and litter on the road and it just popped on then a few hundred ,miles later we hit some heavy rain and ABS light when off and never came on again until when I started it this morn,, to go fuel up..
Jim40216
Aug 16, 2019 01:38 PM
jmo1112
Nov 24, 2017 05:06 PM
superv10
Dec 3, 2009 10:42 AM
kent's f-350
Jan 10, 2009 05:13 PM
dyarumian
1978 - 1996 Big Bronco
Feb 17, 2004 09:09 PM
