Sponsored by: Real Truck
Please help, 2001 excursion v10 sudden power loss
Old Jun 26, 2015 | 02:41 PM
Keyen's Avatar
Keyen
My excursion suddenly lost power after sitting in a long traffic jam. I have a scan guage II set up and didn't see any signs of over heating however when I went to accelerate back up to highway speed my motor revved up to 3000 rpm and just lost power I ended creeping on the side of the road at about 15 mph and barely maintaining that. The motor was not willing to revv up. I reached a spot to pull over and shut it down for about 15 minutes and started back up and drove off with no noticable issues. I have 211,000 miles on this motor and I am going to change my coil packs, I think they have been there since the truck was sold new....I changed four of them to address a miss and have six left, I will also be changing my fuel filter. We are about to pull our camper accross country....about 1400 miles if anyone has had a similar experience I would appreciate any advice you can give me.
Old Jun 26, 2015 | 03:32 PM
ironman1977's Avatar
ironman1977
sounds like it is in limp mode, un hook battery and let set for 10 min then hook back up, this will reset computer. a bad thermostat will make truck act funny and give a flase reading then it will go into limp mode
Old Jun 26, 2015 | 04:06 PM
Keyen's Avatar
Keyen
Forgive my ignorance here......the thermostat you're refering to.....is that the thermostat on the top of the motor that is rated at 195? I also had some spitting and sputtering while it was limping along the side of the road.....Thank you much for your reply.
Old Jun 27, 2015 | 12:39 AM
khangmai's Avatar
khangmai
It could be a wiring short as well caused by chafed wire or rubbed wire. Have a code read, find out which is the problem, locate that device then trace its wiring back to the computer module and exam the wiring.
Old Jun 27, 2015 | 08:39 AM
speakerfritz's Avatar
speakerfritz
with that many miles, I would check the cat as well. some folks pressure test it, others use a heat gun to determine if the heat pattern is correct.
Old Jun 28, 2015 | 01:11 PM
Keyen's Avatar
Keyen
Thank you for the responses, your information has given me more to look at and hopefully solve this issue.
16-F250
Modular V10 (6.8l)
Aug 17, 2023 04:43 AM
BroncoEx
Jul 1, 2010 08:56 AM
JAY DOGG
Modular V10 (6.8l)
22
Apr 14, 2006 10:06 AM
SLE
Modular V10 (6.8l)
Apr 18, 2005 10:28 PM
bcnu2004
Modular V10 (6.8l)
Mar 21, 2005 11:12 AM
