How much Transmission Fluid?
Old Jun 25, 2015 | 04:08 PM
Highboy74's Avatar
Highboy74
I am going to fire up my freshly rebuilt 460 with a C6 attached to it which also has a fresh rebuild. Im running Brad Penn break in Oil for the engine, but Im curious as to how much transmission fluid to dump into the transmission prior to start up? and once started up how much more? In total how many quarts of Lucas Oil transmission fluid am I going to need. Stock pan BTW.
Old Jun 25, 2015 | 09:39 PM
fuzzybob's Avatar
fuzzybob
The book probably calls for type F oil. Did you put any in the TC before install? The transmission and TC will hold 10 to 13 quarts depending on the size of the TC and pan configuration. Put in 6 or so quarts to start then add to the low side of the full mark on the stick. Check again when at temp and top off. Congrats on your new engine and trans!!
Old Jun 25, 2015 | 11:35 PM
Highboy74's Avatar
Highboy74
@fuzzybob, thanks for the advise.
M-S-G
21
Dec 22, 2014 11:25 AM
Superduty450
2004 - 2008 F150
Nov 1, 2014 07:33 AM
bc4x4f250
Jun 15, 2014 06:07 AM
gasgrunt88
18
Jun 8, 2009 03:45 PM
desertstorm-007
Aerostar
Sep 22, 2003 01:55 AM
