Tranmission fluid change
Old Oct 30, 2014 | 08:42 AM
Superduty450's Avatar
Superduty450
I plan on dropping the transmission pan on my 06 5.4 and changing fluid and filter, anybody know how much oil I will need to refill?
Old Oct 30, 2014 | 01:58 PM
1saxman's Avatar
1saxman
No, but I guess you know that will only change about half the fluid. The rest is up in the torque converter. Anyway, check the fluid level with the dipstick on a cold engine, not running. Make a note of exactly where it is on the stick. After putting the pan back on, add fluid to the trans until it equals the previous measurement. Check it later with a warmed-up, running engine to make sure the operating level is good.
Old Oct 30, 2014 | 02:40 PM
Superduty450
I am looking for a qt. amount since I have to go get the oil and don't want to make 2 trips, not planning on having a trans flush done.
Old Oct 30, 2014 | 02:46 PM
97PS250's Avatar
97PS250
I know my first post here but long time Ford truck guy here (30 plus years).
On my 99L which also had the 5.4 I always measured out what I drained and replaced that exact amount and then checked it. My L had the 4R100 with the F250 deep pan and it was usually about 7 quarts
Old Nov 1, 2014 | 07:33 AM
60DRB's Avatar
60DRB
"I always measured out what I drained and replaced that exact amount and then checked it."
What he said.
My pan drop/drain uses approximately 6 quarts of MERCON V.
jawsfree
2004 - 2008 F150
Jul 17, 2013 12:23 PM
terry-louie
Aerostar
Jun 14, 2012 09:22 AM
4x4countryboy
30
Jan 11, 2012 05:56 PM
charlesecarter
22
Jan 4, 2004 12:01 AM
desertstorm-007
Aerostar
Sep 22, 2003 01:55 AM
