Brake light switch question
Old Jun 24, 2015 | 03:33 PM
jco69's Avatar
jco69
I have a 66 f100, brake light switch is on the pedal now, PO switched the column to what looks like a 70 column maybe newer. the plug is completely different and i dont feel like messing with turn signals yet. anyway, my question is how do i wire the brake light swith bypassing the turn signal switch? constant power to one side then the other side to the yellow going to the rear? PS- i have headlights and tailights.....
Old Jun 24, 2015 | 04:35 PM
jowilker's Avatar
jowilker
Don't understand the question, as the brake lite sw has nothing to do with the turn signals operation. The pedal switch should be using the same 2 wires that it was originally. I pulled mine back through the firewall and connected to the 76 switch now at the pedal.
The turn signal is controlled in the column and do share the same two wires going to the rear.
My setup Ford Truck Picture by jowilker | 813147 | Ford-Trucks.com
John
Old Jun 24, 2015 | 04:42 PM
jco69's Avatar
jco69
According to the wire diagram, the brake light switch wire goes to the turn signal switch...... will the brake lights still work without the turn signal switch being hooked up? i have pretty much the same setup as you do and it is using the factory 2 wires. i assumed since one of the switch wires went to the turn signal switch that the lights wouldnt work without it being hooked up
Old Jun 25, 2015 | 04:25 AM
Old_Crow's Avatar
Old_Crow
Correct. If the t/s switch is disconnected the brake lights won't work.
Old Jun 25, 2015 | 05:01 AM
jowilker's Avatar
jowilker
I agree, the turn signal needs to be to be in operation. I swapped in a column from my 76 donor, IDed the wires and had it connected in about an hour.
John
Old Jun 25, 2015 | 08:25 AM
jco69's Avatar
jco69
Old Jun 25, 2015 | 08:27 AM
jco69's Avatar
jco69
Thats whats on my column, not sure what the smaller plug is for, it goes to a "slide switch" at the base of the column. how would i bypass the TS switch so i can have brake lights for now?
Old Jun 25, 2015 | 08:59 AM
ultraranger's Avatar
ultraranger
Originally Posted by jco69
The gray plug on the right is for a Dentside steering column ('73-'79).
The black, flat connector on the left is for the column-mounted NSS (Neutral Safety Switch)/backup lights. The NSS was mounted on the top, lower end of the column inside the cab on '77-earlier model trucks with an automatic transmission. In '78, the NSS was moved to the side of the automatic transmissions.
I installed a '78 tilt column in my '69 F100. I made a 'patch cable' to go in between the column connector and the main under dash harness connectors, so that I didn't have to butcher any of the original main harness wires.
https://www.ford-trucks.com/forums/1...l#post14923738
Old Jun 25, 2015 | 09:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/77 F100/350: THREE different T/S switches.
1978/79 F100/350: THREE different T/S switches, different than 1973/77.
Old Jun 25, 2015 | 09:38 AM
jco69's Avatar
jco69
so.....if i was to "butcher" this, can anyone tell me which wires from the column i need for the 66 harness to atleast get brake lights?
Old Jun 25, 2015 | 11:30 AM
ultraranger
"10" is the slot on the Dentside column connector for the brake lights. On my '69, the brake light wire from the truck harness is dark green.
You may have to look up the electrical schematics for your model truck, and from the Dentsides, to figure out the integration from the original wiring to the later model column wiring. --this is how I figured out the wiring from my '78 column to the '69 main wiring harness.
christofalex
Dec 4, 2016 07:59 PM
Fishin76
Jan 8, 2010 05:57 PM
greeneon_01
Electrical Systems/Wiring
Apr 26, 2009 09:53 PM
59INA40
Dec 14, 2005 08:54 AM
toolman617
Aug 3, 2005 03:37 PM
