AC Charging
Old Jul 11, 2015 | 05:40 PM
tjc transport's Avatar
tjc transport
i ain't rite
i am not a fan of 134-A conversions at all. R-12 is still readily available, and works much better than 134-A
Old Jul 11, 2015 | 10:59 PM
twigsV10's Avatar
twigsV10
Originally Posted by tjc transport
the problem is not with compressor failure, the problem is that R134-A is not compatable with the oil used in the R-12 system, and it almost always turns to a black sludge crud that plugs up the orifice tube and other parts, causing the system to self destruct.
I didn't add any oil maybe that has something to do with my luck. To be honest when I recharged with 134a I was really only expecting to get a year or two out of the Ranger but it ran like a champ for seven years and I kind of got attached to it and put a ton of work into a engine, transmission, transfer case and rear axel swap from another truck last winter. And even though it will still freeze me out of the cab on the lowest fan setting at 90° Outside, If I had to do it again I would do a complete change of the AC system
Old Jul 12, 2015 | 06:53 AM
tjc transport
i ain't rite
the 134-A does not use the same oil R-12. even if you do not add any oil to the system, it usually does not play well with the improper oil. you have been very lucky dodging the black death bullet!!!
Ex-Jermin
Aug 17, 2018 10:55 AM
hardeyf150
2009 - 2014 F150
Mar 13, 2017 06:39 PM
mrgn_mtt
May 13, 2008 10:59 AM
fordman1090
17
May 7, 2008 05:56 AM
302VAN
Apr 3, 2008 03:22 PM
