cannot get ac system to recharge
Old Aug 11, 2018 | 05:36 PM
Ex-Jermin's Avatar
Ex-Jermin
2000 v10. need some help from the AC gurus here.
last summer the AC worked adequately. this year not so much. did not ever see the infamous "dump" out of the back end. No issues with front or rear units blowing hot when on cold. AC is blowing "cool" air currently (front and back are the same temp). Cool = lower than ambient temp but not any where near cold. compressor looks to be operating and engaging properly with no strange noises. ac pipes get hold and "cool". i have condensation dripping from the back compressor as normal. both condenser and evap coils are clean. The compressor is engaging off and on regularly at 2 seconds on and 8 seconds off.
I figure that the system most likely has a leak so i get some AC Pro with UV stuff to add coolant and find the leak. I purchased the can of r134 and the hose/gauge separately. Put the two together and plugged it into the low pressure side. Cranked up the motor with Max AC on blast and tried to add the r134. the gauge reading was going up and down as the compressor turned on and off. The pressure readings were in the green with compressor engaged and then it dropped to white when the compressor turned off and was zero when i squeezed the trigger. I followed the instructions and watched several videos and even weighed the can of r134. the can did not get cold, make any noise, loose any weight and my AC did not start blowing colder. After several attempts to add r134 i figured that because the compressor was only on for 2 seconds that it might not be drawing in any new refrigerant. so i jumped the low pressure switch to keep the compressor engaged and tried again. no joy. i am at a loss as to what to do now other than take it in to ford and pay out the nose to get it figured out. I did notice that when I shut off the motor i can hear a hissing sound coming from the dryer/accumulator area. not sure if that is normal or not...
so i am guessing i either something on my ex is broken or maybe my new r134 can/hose is bad or the cap didnt puncture the can? does that happen? i am afraid to take it apart as it is pressurized...
TIA
Old Aug 11, 2018 | 07:07 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Going to follow along and see what the HVAC experts have to say about this as that is not my area of expertise but I have always wondered how those cans work if your systems refrigident has already leaked out and compromised the vacuum.
the way I understand it the vacuum sucks in the new refrigident, that is why the real way to charge the system is to draw it down with a vacuum pump first. But then again.... I am not the AC guru so let’s wait for real answers
Old Aug 11, 2018 | 07:20 PM
seville009's Avatar
seville009
Take it to an a/c shop instead of a dealer; they’ll probably have a better understanding of what may be wrong with it.
Old Aug 11, 2018 | 07:49 PM
Flyboy1100's Avatar
Flyboy1100
maybe someone else did that repeatedly and has over 25oz of oil in the system.....this was my problem, previous owners who half **** everything suck.
get a real set of manifold gauges
Old Aug 12, 2018 | 06:41 AM
DSMMH's Avatar
DSMMH
If your AC is not cooling, the R134a has leaked out and replaced with air. You can try to put the big can of R134a with fancy SS hose and gauge in it and it will not work. You must find the leak, fix it, pull a vacuum on the system to determine the leak is fixed, then recharge. There is dye put in the system and checked with an UV light to find leaks. Plus the system will need an oil charge. I would not take to a dealer. Any good repair should has a R134a recycle machine. These machines do it all. They evacuate the system, recapture any R134a, and automatically recharge to the correct amount of R134a. I have had to recharge my X every 3 years. I have had it for 13 years. I have a small leak around my compressor shaft seal. I had it done back in June. Cost me $135 for the service and the R134a. Eventually, I will have to replace the compressor, air dehydrated and the filter tube. Remember, if the AC is not cool, it is because air is in the system and must be removed.
Ed
Old Aug 12, 2018 | 07:14 AM
01__Excursion's Avatar
01__Excursion
There is most likely air in the system yes, but probably not to the extent already listed. At this point you may be over charged with oil, and you may have a poor refrigerant line tap. My Ford is OK, but on one of my Chevy Astro service vans, I need to clamp my charge hose adapter to the refrigerant line so it will properly engage/depress the schrader core. Air and moisture are both "non-condensables", and typically migrate to the condenser. I can't tell you with exactness on the Excursions, but standard safety equipment on an A/C system will include a high pressure cut-out, (if over pressure), a low pressure cut-out for (low pressure) situations, as you have already become aware of, and sometimes a high pressure blow off to simply relieve the high pressure.
The most important thing you need, if you are doing to do this yourself, is a proper set of gauges, rated for 134A.
When you go to the doctor, the first thing they do is triage you, the same needs to happen with your A/C, especially if you are not the original owner and do not know the history.
Your pressures, both low and high will tell you a lot about the system. Since you seem to be short cycling, you are most likely low on refrigerant, the leak dye is instrumental to have in there, but for a leaky service port, which could be your culprit, not so much. A quality electronic leak detector, or soap bubble leak detector will help you with the service ports, while the leak dye is great for the evaporators, and O ringed connections.
Old Aug 12, 2018 | 12:24 PM
Ex-Jermin's Avatar
Ex-Jermin
So it turns out that all new cans of r134 made in 2018 have to be self sealing. The can I have is a self sealing can but that is not listed on the can label any where or in the instructions. I called AC Pro and they told me I need to go buy an adapter to use with the hose I have. So I will be getting one tomorrow....
Old Aug 12, 2018 | 12:31 PM
Ex-Jermin's Avatar
Ex-Jermin
I just want to add a little r134 with the UV dye to try and identify any potential leaks. Not trying to bandaid my system here, just diagnose/ fix myself if possible. Next step is either get the full guage/pump to evacuate and recharge myself or take it in. Local dealer wants $200 just for diagnostics/evac plus $$ for new r134 and Jiffy lube quoted me at $80 to evacuate and then $40/lb. for r134....Haven't called around to anywhere else....
Old Aug 12, 2018 | 01:59 PM
Flyboy1100's Avatar
Flyboy1100
i think i spent 160 on mine at a local shop that was for evacuate/testing/4.5lbs of r134a. the Ex is definitely not a small system!
Old Aug 12, 2018 | 05:09 PM
Jesse Walter's Avatar
Jesse Walter
I just had mine done at a Valvoline oil changing place after my body off head stud install. It was about $120. They check for leaks and fill.
Old Aug 12, 2018 | 05:21 PM
Markken's Avatar
Markken
If you do not already own the stuff to do it, vaccum pump, a real set of 134a gauges, a bottle to draw the refrigerant into using the vac... just have jiffy lube, or another shop, do it for the $120'ish.
A good vac pump will cost more then the shop doing it, and if i recall correctly a decent set of 134a gauges new is around $80.
Old Aug 16, 2018 | 12:02 AM
Ex-Jermin's Avatar
Ex-Jermin
Update. Got 2 cans of r134 into the system. Air temp from the vent was 49. outside was reading at 80. So the system was low. Took a uv light to everywhere I had access to without taking off panels and didn't see any trace of a leak. I did see some uv reflective stuff on the bottom of the compressor....so I may be in the market for a replacement in the near future....what I did see was dry, possibly from the first can a few days ago? Nothing looks wet....Does anyone know if the leak stop these cans boast about actually works? I am going to give it a few more days in this 90 degree heat and drive the ex around and see what happens with the compressor...
Old Aug 16, 2018 | 12:03 AM
Ex-Jermin's Avatar
Ex-Jermin
Old Aug 17, 2018 | 10:55 AM
Flyboy1100's Avatar
Flyboy1100
Stop leak is bad in general, especially in AC systems
my understanding the new he FS10 compressor is notorious for bad front shaft seals or the split case seal. I just replaced my compressor this spring because of a bad front seal with a new Motorcraft one. Brand new Densos are 1/2 cost of new MC at 125.00. If you only have to pay someone to vacuum and charge the system it is actually very cheap to repair....
hardeyf150
2009 - 2014 F150
Mar 13, 2017 06:39 PM
garagegods
17
Jul 12, 2015 06:53 AM
p8ntballa9362
May 18, 2009 03:02 PM
fordman1090
17
May 7, 2008 05:56 AM
vanlohd
Aug 3, 2005 06:06 PM
