no 3rd or 4th gear?
Old 06-24-2015, 03:33 AM
shadetreescotty's Avatar
shadetreescotty
shadetreescotty is offline
Exclamation no 3rd or 4th gear?
I have a 96 f150 with 4.9l and 2wd e4od. I recently developed a transmission leak from the bell housing. Transmission operated correctly until I towed vehicle to a shop and then pulled tranny and replaced front and rear seals and the rear main engine seal (since I was there). After replacing seals and checking/ adding fluid then running through the gears. everything seemed fine until I took her on the highway. It never shifted into 3rd or 4th and the leak was fixed.I then removed tranny again. drained torque converter. checked internals of torque converter and all electrical plugs. reinstalled tranny after finding no apparent issues or damages. I then connected obdII scanner for codes and got none. no flashing OD lights. no noises. no trouble shifting into reverse or 1st and 2nd. no clue where to go from here. any advice would be greatly appreciated.
Old 06-24-2015, 04:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,589 Likes on 1,063 Posts
My guess is a stuck 2-3 shift valve in the valve body.
BDFD
18
03-26-2021 12:42 PM
therigwelder
1997 - 2003 F150
05-02-2017 10:23 AM
HMS
1999 to 2016 Super Duty
07-11-2013 10:14 PM
73strokin
17
01-25-2013 03:15 AM
cowboy133
01-23-2005 05:36 PM
Quick Reply: no 3rd or 4th gear?
