ARP head-studs and leaking headgaskets
Old Jun 23, 2015 | 12:02 AM
maxtruck00's Avatar
maxtruck00
2007 f250 6.0l auto trans 4x4 35" tires
about 17k miles ago I replaced the head gaskets with factory gaskets, along with ARP headstuds. the heads, intake, and exhaust manifolds were all machined for flatness. Also did all the other things that need to be done... SCT fitting, stand pipes, injectors, glowplugs, egr delete, new turbo, uppipes, waterpump, BPD remote oil cooler and filter, basically everything that bolts to the short block was replaced. along with the PHP FICM tuner, and SCT with matt's tunes.
Today during an oil change i noticed a tiny bit of dried coolant around the degas cap!
Hooked-up my BPD headgasket testing tool, and sure enough i get bubbles in the bottle.
With the EGR being deleted i have to assume i blew a headgasket.
i am blaming it on SRT+ with PHP 80hp tune, and 35" tires, plus the daily mountain climbing around here.
any ideas other than a head gasket?
My new plan is to pull the cab, re-use the ARP studs and install UCF fire ringed heads. -i'm kind of thinking about a cam swap at the same time?
looking for input here.. appreciate it!
Old Jun 23, 2015 | 01:44 AM
Yahiko's Avatar
Yahiko
To do the fire rings right I think the block needs to be done also.
Or I may be wrong.
Is the EGR a remove delete or a welded cooler type?
Sean
Old Jun 23, 2015 | 08:45 AM
jsm180's Avatar
jsm180
If it was mine I would replace the degas tank cap first and see if the problem returns. If it does, then put a pressure gauge on the coolant system and see how much pressure you are building. What is a BPD headgasket testing tool? Didn't see anything on the BPD site.
Old Jun 23, 2015 | 08:51 AM
KDAVID1's Avatar
KDAVID1
More than likely if your original job failed you didn't have heads flat--just my thought.
Old Jun 23, 2015 | 09:19 AM
87crewdually's Avatar
87crewdually
...Or contamination of the surface upon installation ......or improper/uneven torque with an inaccurate torque wrench.
Were these new heads or reconditioned? Maybe one is cracked.
You could pull the glow plugs and pressure test each cylinder on TDC and watch for bubbles in the coolant system. This will narrow it down so when it comes apart you will have an idea where to pay attention looking for failure.
Old Jun 23, 2015 | 11:46 AM
KDAVID1's Avatar
KDAVID1
True--should have spelled out more--but it comes down to the mating surface and torque
Old Jun 23, 2015 | 02:28 PM
maxtruck00's Avatar
maxtruck00
BPD bubble tester: Ford 6.0L Blown Head Gasket Tester
I Should say i'm interested in the o-ringed heads not fire ring heads.
The heads went to a competent machine shop and were cleaned, resealed, and surfaced.
We spent hours cleaning the block surface to ensure it was debris, and oil free.
My thought is the heads wrapped, and/or the studs backed off?
Or maybe the block deck is damaged?
If the block is damaged would the o-ring heads seal? The machine shop that did the heads said the heads had a groove worn in them from the head gasket, caused by the head gasket vibrating due to loose head bolts.
Old Jun 23, 2015 | 03:02 PM
Maxium4x4's Avatar
Maxium4x4
You need to inspect what failed, normal stud jobs hold when done right.
Old Jun 25, 2015 | 08:30 PM
maxtruck00's Avatar
maxtruck00
Through extensive research i have found maybe a couple oops's.
Re-torquing the studs 12 hours after they are installed.? -i don't remember seeing that in the install guide, but it is on a few forum posts.
Rocker box bolts; ford says are un-necessary, and could cause uneven pressure on gaskets.
Old Jun 25, 2015 | 08:58 PM
Maxium4x4's Avatar
Maxium4x4
You have a torque sequence, 3 step, when done, that is it.
Old Jun 29, 2015 | 07:55 PM
maxtruck00's Avatar
maxtruck00
is there a preferred compression tester?
Old Jun 29, 2015 | 08:55 PM
Jeff Watts's Avatar
Jeff Watts
I'd say keep your shorts on, and try a new cap on the puke bottle, then start moving up from there.
Old Jun 30, 2015 | 12:53 AM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
Did you try and get the block "clean"? The stains are of no bother to the gasket sealing. We look for flat and debris free. The stains are ok to ignore. I've heard of people cleaning the block trying to get it to bare iron. That's a supreme "no no".
Old Jun 30, 2015 | 08:45 AM
dannyboy950's Avatar
dannyboy950
Very true you can cause more harm that good. Especially if useing a high speed air grinder with small dia. pads cleaning by hand. you can actually cause dips and uneven surface.
If you need a block decked have a machine shop do it. They will adjust dimensions accordingly.
Old Jun 30, 2015 | 04:45 PM
maxtruck00's Avatar
maxtruck00
If i'm getting bubbles in a bottle of water using the BPD testing tool; doesnt that mean the headgaskets or the EGR is leaking?
Since the EGR is deleted, it pretty well narrows it down?
The degas bottle and cap were replaced when i did the studs about a year ago.
