02 excursion transmission temp
Old Jun 22, 2015 | 08:30 PM
challl80's Avatar
challl80
02 6.8 4x4 excursion. When I start the truck cold, the trans temp gauge immediately moves to "running" temp. Not really sure how this happens, I'd figure that if the xducer was trash it would ride all the way high or all the way low. Any ideas what's happening here? I'd sure like a functional gauge...
Old Jun 25, 2015 | 01:59 PM
challl80's Avatar
challl80
nobody in the transmission section has any idea why this guage might be reading improperly, or where to find it and replace it? Trouble shoot it?
Old Jun 25, 2015 | 02:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I do! I do! I don't know how I missed your post when you first put it here.
The "gauge" is an idiot light with four positions. Below 50F it reads cold. From 50F to 230F it reads right in the middle of the range. From 230F to 260F it reads yellow. Above 260F it reads red.
There is nothing to troubleshoot. It's working as designed.
Old Jun 25, 2015 | 04:01 PM
challl80's Avatar
challl80
You're the man Mark! I didn't think that ambient temp would register on the dash...but if 50F is the low point, it would have to register. So my next question is this...probably impossible, but is there any way to swap out the transducer for one that reads actual temp and have it display on the dash? I know I can install external sending unit and external guage, but I'd like to avoid that if possible...
Old Jun 25, 2015 | 09:26 PM
Mark Kovalsky
The problem is in the programming for the instrument cluster, not the temp sender. The sender is sending real data to the PCM, the PCM sends the actual temperature to the cluster, and the cluster processes this data and outputs what you see on the gauge.
Old Jun 26, 2015 | 09:36 AM
challl80's Avatar
challl80
Wow...thats actually pretty bad that it would be purposely dumbed down. I suppose the average customer might go insane watching the temp fluctuate in real time...but thats really what I want. I'm certain that there's probably no way to flash or modify the cluster to fix this...
Is it bad that I want to try and get the tranny hot enough to move it into the yellow on purpose just to verify that its working? sounds insane when i say it out loud...
Old Jun 26, 2015 | 01:05 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The '02 has the OBDII port right? the ScanGauge II will prob give you true trans temps. If not, you CAN buy and install a monitor gauge to read real temps.
1991ford_trucker
Oct 29, 2010 08:45 AM
54deuce
Modular V10 (6.8l)
26
Jan 14, 2010 12:15 PM
raineytx
Aug 11, 2005 09:11 AM
Bewbs
3.8 & 4.2L V6
Sep 28, 2004 05:50 PM
rickauf
Jan 7, 2003 04:38 PM
