how do the doors fit I would ck them out and keep them in your thoughts as you move the cab around
The doors fit pretty well, but I have NO rubber seals in or around the doors. They line up pretty well though, and I'm not expecting any problems there. It's a pretty solid cab, from what I can tell without stripping it down to bare metal. I have one hole in the passenger floor which I will patch once I get a welder.
But thanks for the heads up. I was not thinking about the doors when I suggested lifting the corner that's on the frame.
As I was trying to go to sleep last night (never an easy task) I was thinking that I could probably just remove the left side arm since the cab is already resting on the frame. That way I can see if the bushings are shot or the arm is bent/worn oblong or whatever.
Does anyone see a problem with that thinking?
Joe, the arm is designed to move, giving the cab some flexibility. I can't remember exactly how did it, but I jacked up the rear of the cab slightly with a bottle jack, to take the pressure off the mount bolts. it also allowed me to adjust the cab to make reinstalling the arm and bolts easier to line up.
That's what I was thinking I'd do... use some wood to protect the cab, and jack it up slightly, then position it where it should be and install the corrected arm.
If you are going to install new arms and the bushings you will want two jacks. One to support the cab at the rear corner, and another that will be used to jack up the arm into position. With the new rubber in there you will not be able to push the arm up by hand.
I found the easiest way to do the install was to completely assemble the frame side of the arm with the rubber bushing in place and then use a jack to lift up the cab end of the arm. Using the two jacks will allow you do lift the arm and adjust cab height with the 2nd jack to get the bolt lined up.
That's right and I would have a helper, one guy on the jack or jacks, and one guy pushing in the bolts when they line up.
Although I don't recall exactly, I know that I only used 1 jack. I think that after I had the cab raised I blocked it on the frame rail. Don't tighten either bolt until you have them both in place.
Get the beers in the ice box, I'm on my way over to help you out.....(I would if I were closer)
The mounts aren't too bad to replace. At least on your truck you don't have to deal with that extra steel section on the running boards of the 48-50 trucks.
I completely rebuilt mine for not too much money. Here's a link to what I did; https://www.ford-trucks.com/forums/1...t-rebuild.html
Thanks Joe. Yeah, that's what I was going to try. I've got a really good floor hack and a brand new bottle jack so I figured I'd have whatever I need to get this done.
Bobby
Well, okay Bobby. Jump in the truck and get over here. I got the parts and I'm gonna work on Betsy this weekend. Beer's in the kegerator.
