Sponsored by: Real Truck
FREAKING dome light!!!
Old Jun 22, 2015 | 12:19 AM
jiujitsustudent's Avatar
jiujitsustudent
I've searched the posts and haven't found a problem similar to mine, so: the dome light/under hood light keeps blowing the fuse. If anyone has the same issue and found the culprit can you help? I can't tear the entire interior out to try and chase down the short. Just wondering if anyone has found a common area this circuit shorts out!
Old Jun 22, 2015 | 08:21 PM
ligito's Avatar
ligito
Check the grounds.
Old Jun 23, 2015 | 01:37 AM
jiujitsustudent
aye, i have, it seems to take a minute to get enough resistance to blow the fuse, IE it doesnt blow immediately. its still driving me crazy and short of tearing the roof liner out, i cant seem to isolate where the issue is
Old Jun 23, 2015 | 02:37 AM
xr7gt390's Avatar
xr7gt390
If it takes awhile the problem might not be a dead on short. A few things I would check are, are you using the correct size bulbs and the correct size fuse. Next I would check the amps going through the fuse block.
Old Jun 23, 2015 | 05:50 AM
asdrew's Avatar
asdrew
Does the fuse still blow if all bulbs are physically removed?
If so, a wire or one of the fixtures may be the issue. If not, try adding the bulbs back one by one until it blows, then you may have narrowed down the issue.
Vsanzbajo
Dec 19, 2012 02:20 PM
ttttmaxx
Oct 23, 2009 09:57 AM
themicro
Nov 16, 2006 02:40 PM
Neutron
Nov 28, 2005 11:09 PM
firefighter
1997 - 2003 F150
Sep 19, 2000 08:37 AM
