No WTS light?
Old Oct 23, 2009 | 08:03 AM
ttttmaxx's Avatar
ttttmaxx
No WTS light?
Hi gents,
The other day my 96 stopped showing me the WTS light. The truck starts and runs fine. What would be the most common problem to cause this light not to come on? The voltage is also being pulled by the glowplugs when first cranked as the needle on my voltmeter shows. Just like all things to work as they should and not seeing the WTS light bugs me. Thanks guys
Old Oct 23, 2009 | 09:49 AM
Hussler's Avatar
Hussler
Guess it could be the bulb itself. It uses fuse #17 10A inside the drivers compartment. That fuse also protect some other thing such as ...
1. CEL Lamp
2. Warning chime
3.
Old Oct 23, 2009 | 09:57 AM
ttttmaxx's Avatar
ttttmaxx
Yes, I will check that fuse out. I too was leaning toward the bulb. Wasn't sure what fuse that light was tied to. thanks!
