Starter/ Ignition
Old Jun 21, 2015 | 06:05 PM
lossleeper's Avatar
lossleeper
Starter/ Ignition
I'm sure this info is easy to find, but I can't seem to find a specific diagram for what I want. I'm looking for some kind of diagram or even a drawing showing all the wires going to the starter,distributor and ignition. Any and all help will be appreciated, thankyou.
Old Jun 21, 2015 | 06:08 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Welcome to FTE!
It would really be helpful if we knew what year truck and what engine you have.
Old Jun 21, 2015 | 06:15 PM
lossleeper's Avatar
lossleeper
It's a 1948 F--1 with a sbc 350.... starter and ignition are usually the same for most applications I would assume. .....
Old Jun 21, 2015 | 07:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Google is your friend. The starting circuit for a SBC is different than for a 48 F-1. The stock ignition switch and starter switch could be used or a more modern switch could be used. Since your other thread is asking about columns, that potentially has a switch in the column, you have to decide that first. Same for the ignition, depends whether you have electronic or point ignition and which kind of switch you use. But from a google image search you can find examples of both and adapt to fit whatever you end up with.
Old Jun 22, 2015 | 06:58 AM
lossleeper's Avatar
lossleeper
Yeah I've Google it,but getting a lot of different pictures. I'm using a universal ignition switch right now with a HEI distributor. I tried to crank it up last night, but had battery and fuel pump issues,I'm gonna try again today.
seedpress
1978 - 1996 Big Bronco
Jul 2, 2015 04:43 PM
Jadgarul
Apr 3, 2012 10:47 AM
silver9696
Jun 27, 2010 12:30 AM
Rayray1102
Sep 8, 2009 06:42 PM
Vern Anderson
Electrical Systems/Wiring
Nov 4, 2004 11:43 PM
