Boost & EGT numbers
Old Jul 29, 2003 | 09:56 PM
myst's Avatar
myst
Boost & EGT numbers
Has anyone put a set of pyro and boost gauges in a 6 liter yet?? I am fixing to put a set in my new truck. Just wondering what egt's and boost the 6 liters are putting out.
Old Jul 30, 2003 | 05:56 AM
Rich H's Avatar
Rich H
Boost & EGT numbers
Let us know what you get. I've been curious about that ever since I put a boost and EGT gauge on a small 4-cyl.
Old Jul 30, 2003 | 01:28 PM
JoeBobBubbaJohn's Avatar
JoeBobBubbaJohn
Boost & EGT numbers
Mine sees a max EGT of about 1050 degrees at full load and a max boost of about 24psi. The worst part is you have to really wind it out long and hard to achieve full boost. So much for that "new/improved" VGT turbo! It doesn't respond as well as my old Cummins didn't with it's HX35 Holset.
JBBJ
Old Aug 1, 2003 | 12:38 PM
phil385's Avatar
phil385
Boost & EGT numbers
My 6.0 runs great and in the Texas heat it is very easy too see 1200* on a full throttle run. Boost is very responsive and I end up with a max of 26 psi. I have never been able to get EGT over 1200 with or without a load. My only real complaint is 13.5 mpg around town.
Joe Bob: might i suggest a trip to the dealer - alot of people have had bad VGT solenoid problems - or you could go get your old Cummins back?
~Phil
Old Aug 1, 2003 | 02:52 PM
JoeBobBubbaJohn
Boost & EGT numbers
Phil:
I did the VGT solenoid replacement thing and it made no difference. Boost still comes up really slow from dead stop. Your truck must be fueling a lot better than mine based on the EGT and max boost you're seeing. It probably runs better too. Mine is a real dead dog.
JBBJ
Superduty450
6.4L Power Stroke Diesel
13
May 29, 2014 10:02 PM
Powerstrokin_350
Aug 7, 2009 03:49 PM
davidcam
Nov 2, 2007 04:21 PM
jbullfrog
Mar 22, 2006 06:38 PM
