Concentric Slave Cylinder
Old Jun 19, 2015 | 07:55 AM
msestak's Avatar
msestak
I have an 87 F-150 4.9L with a ZF-5 speed transmission. My clutch slave cylinder has been leaking for some time so I finally decided to pull the transmission and replace it. I got the transmission out and removed the bolts from the concentric slave cylinder, but it seems that no matter what I do it will not come off. Any suggestions?
Also if anyone has a logical explanation as to why Ford would design this the way they did, I would love to hear it. Why would they put a part that is semi-common to failure in a place where transmission removal is necessary to replace it? You would think they could make some sort of access panel or something on the bell housing.
Old Jun 19, 2015 | 08:01 AM
jas88's Avatar
jas88
It's probably seized to the input shaft bearing cover - just soak it in some penetrating oil and tap on it back and forth with a hammer.
The design is a good one if you know how a "regular" TO bearing works. This is better IMO.
Old Jun 19, 2015 | 01:08 PM
msestak's Avatar
msestak
Ok I will try that. I also read on some other posts that DOT 5 is recommended to extend the life of the parts. Can I simply drain out the DOT 3 that is in there now and refill it with DOT 5 or will I need to flush out the system?
Old Jun 19, 2015 | 08:38 PM
jas88's Avatar
jas88
Yes you can just drain and refill IMO.
Old Jun 19, 2015 | 09:17 PM
dixie460's Avatar
dixie460
Don't mix DOT3 and DOT5. One is silicone and the other is... whatever regular brake fluid is made of. I'd flush everything out first. Never tried it but I hear if you mix the two in a glass jar you can literally see why it's a bad idea.
Old Jun 20, 2015 | 12:23 PM
'89F2urd's Avatar
'89F2urd
The internal slave is better, in a perfect world. It allows for greater release pressure with an easy pedal throw. Beefy clutch springs with internal slaves feel as soft as factory, whereas heavy springs combined with external conventional can put up one hellofa fight at the pedal.
In a world where parts wear out, it can be a pain in the *** and perhaps more trouble than its worth.
Go with an oem slave and you won't have to mess with it for years and years. Even a used OE slave that's in good shape is better than an aftermarket slave.
jethrodean
Dec 26, 2017 08:57 PM
frankiethethumper
Jul 15, 2017 09:15 PM
FiftyCalUSMC
Nov 14, 2012 10:54 AM
bigredman
Feb 8, 2006 12:25 PM
byerly
Jun 14, 2001 03:00 PM
