starting issue
Old Jun 18, 2015 | 04:52 PM
dalihari's Avatar
dalihari
starting issue
Okay, I have a 2003 F350 with the 7.3L. I just got the fuel line replaced drove it home from the shop, parked it. and now it wont start. I Checked the fuel filter, replaced both batteries, and replaced the cps. Still tries to start and then stops and just wont turn over. Any ideas on what could be the issue?
Old Jun 18, 2015 | 05:49 PM
jhl3's Avatar
jhl3
How much fuel is in the tank? What is your oil level? How long does it turn over when you attempt to start it before stops turning over?
Do you have gauges?
Old Jun 18, 2015 | 09:17 PM
dalihari's Avatar
dalihari
How much fuel is in the tank? its sitting at a half tank
What is your oil level? I Just topped it off the other day
How long does it turn over when you attempt to start it before stops turning over? after i let the glow plugs warm up it hesitates then tries to crank but just wont turn over, then it sounds like the batteries are dieing but the battery gauge reads normal.
Do you have gauges? It has the stock gauges, and i have a bully dog chip in it, and its not saying that there is any codes.
Old Jun 19, 2015 | 08:17 AM
JOHN2001's Avatar
JOHN2001
Starter or batteries
Old Jun 19, 2015 | 08:26 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Agreed. Check all your battery connections, including the one on the starter. Try jump starting it. The sluggish starting sounds like you either have bad batteries, bad connections to the batteries, or a bad starter.
Old Jun 19, 2015 | 10:30 PM
Mohawkwoodman's Avatar
Mohawkwoodman
Starter solenoid
6_Myles
16
Dec 12, 2018 06:01 PM
Rlopezk93
Oct 2, 2017 10:28 AM
zay1016
30
May 30, 2016 09:15 PM
grileyh
May 31, 2014 10:43 PM
Tyhudg
Dec 18, 2008 04:00 PM
