Hpop lines
Old Jun 17, 2015 | 05:01 PM
adam10's Avatar
adam10
Hpop lines
I was changing fuel filter other day and noticed I had more dampness than usual up top.the driver side hpop line is damp at both fittings and there is wetness going back across intake plenum on that side and some oil wetness in valley.do these lines tend to deep before they go?passenger side is bone dry.if it is bad where is a good place to get them.local auto parts don't carry.and which tool removes them? Thank you
Old Jun 17, 2015 | 05:18 PM
Thomas White's Avatar
Thomas White
Several places sell the tools. Diesel O-Rings for one. Personally, I like the one with the 45* bend because it works well on the 6.0's as well. That one is available from Freedom Racing. If you're savvy, you can spread the collars with a trim tool or Flat Driver as well.
Purchase the entire kit to include, fitting. They had a running change. Everyone says to use Loctite 292. I have never used anything and have yet to have a comeback.
You can change both Supply without removing the pump.
Old Jun 17, 2015 | 05:20 PM
binuya's Avatar
binuya
I had an HPOP line fitting leak a while back and got the tool and fitting from Riffraff. It was spraying out a fine mist which got worse quickly. Here are the links to what I got, but there's also an o-ring set so you have the option to rebuild your fittings:
HPOP Line Fitting - Cylinder Head - Riffraff Diesel Performance
HPOP Quick Disconnect Hose Removal Tool 99-03 - Riffraff Diesel Performance
Old Jun 17, 2015 | 06:45 PM
adam10's Avatar
adam10
I cleaned the fittings up good and around them just to make sure it wasn't oil seeping out of the intercooler boots.hope if it is that it holds till next week.gotta take my old camper in tomorrow and pick up my new one then going camping this a weekend.thanks for the help.
rtazz17
Apr 30, 2011 09:40 PM
ScottInTexas
1997 - 2003 F150
Apr 14, 2009 08:36 PM
SVLERF250PWRSTRKE
Mar 20, 2008 05:09 PM
wlihntr
16
Feb 7, 2008 09:24 AM
dcwhipple
Dec 17, 2006 06:22 PM
