Tire size
Old Jan 3, 2011 | 07:23 PM
deere55's Avatar
deere55
Tire size
What are the largest tires that will fit on a 1991 F350 4x4 stock rims and stock height?
Specifically with mud or all terrain tread.
Old Jan 3, 2011 | 08:24 PM
IDIDieselJohn's Avatar
IDIDieselJohn
On the stock rims I think you can't go wider than 285, height I think, but I could be wrong, 33"
Old Jan 3, 2011 | 08:55 PM
deere55's Avatar
deere55
Ok, well forget about the rims, but what's the maximum size tires you can get under there without lifting the truck? 33 x 12.5s?
Old Jan 3, 2011 | 09:34 PM
threefiftyone's Avatar
threefiftyone
I have personally seen 315's on a lot of factory rigs with 8" wheels. Biggest I've ever had with no problems has been 305's (33's)
Old Jan 4, 2011 | 09:28 AM
jokerforever's Avatar
jokerforever
I just put 35/12.5/17s on my 97. No lift, but a good bit of triming to the front bumper. The 91s use a different bumper and I've heard that you don't need to trim as much if anything from them. The key is the offset of the wheels. I made a mistake and got wheels with too much backspacing. You want to look for something with 4"-4.5". This will make your tire stick out a little with 8" rims and a lot with 10" but if you go any closer you will rub the tires on the springs.
As for stock wheels, I was running 285/75/16s on the stock 7" wide rim without problems but I would suggest a wider wheel if you can get it.
As for the max tire size, I've seen pics of someone on here running 37s. He had to pull his bumper and fab a new one but he said that they fit without rubbing with no other mods. I would think it would be the same as my truck. A lot of neg offset to get the tires away from the springs, then making clearance to the sheet metal as needed.
Old Jan 4, 2011 | 11:10 AM
deere55's Avatar
deere55
I've been considering 305/70/r16s or maybe 315s. I just wanted to make sure that they would fit before I had to make the venture even more expensive. Is an 8" rim enough for 12.5s?
Old Jan 4, 2011 | 03:02 PM
hav24wheel's Avatar
hav24wheel
10 would be better
Old Jan 4, 2011 | 04:29 PM
jokerforever
Check with the tire manufacture. Most manufactures are similer but every now and then there is an odd ball thrown in. Here are the specs for a Firestone 315/75/16
Firestone Destination M/T
If you look at the "Rim Width Range" you can see that an 8-10" rim is fine. I'm running my 35s on a 8.5 rim and they fit great. Take note though, a tire will be taller and narrower than the same tire mounted on a wider wheel. It may not be much but it can be the difference between clearing and not clearing. Me personal, I think a 35 looks better mounted on 10" rims than anything else and when I get back in the market for a set of wheels with a better offset I'm going to try to find a 10" rim.
Old Jan 4, 2011 | 08:06 PM
threefiftyone
8" is fine. dont spend the extra bucks unless needed
