Need help with supplemental braking system
Old Jun 16, 2015 | 12:26 PM
pacnorwest's Avatar
pacnorwest
2015 SD 6.7
I'm installing the USGear Unified Brake System control in the truck cab and hope that the FTE brain trust can provide some answers before I go rooting around in the electrical system.
1) Where does one find the power coming off the brake switch (when activated) and connect into it for a supplemental brake system?
2) Where does one find a positive "switched" power source and connect to it?
Thanks in advance. . .
Old Jun 16, 2015 | 01:01 PM
obwielnls's Avatar
obwielnls
I usually go straight to the brake switch myself, It always seems handy and should be easy to find. The only problem you might run into is, it could be a switched positive or negative. You'll need someway to test it.
Can't help exactly on the accessory wire but the fuse box is usually a good place to tap into.
Bill
Old Jun 16, 2015 | 06:09 PM
Just Strokin's Avatar
Just Strokin
The 2015 workshop manual shows the wire to be Blue-Orange (BU-OG) after it exits the BCM. I would not connect it prior to the BCM, i.e., the switch on the brake pedal. There is Fuse 31 that is classified in the owners manual as
Customer access
Trailer brake controller (brake signal)
There are two locations to find the BU-OG wire. One is near the heater (workshop manual says right kick panel but connector photo show closer to heater and TPMS module) or near the trailer brake controller where it might change color to Yellow-Green (YE-GR) at connector C2108.
Hope this helps
Just Strokin
double post....please delete
Old Jun 18, 2015 | 09:51 AM
pacnorwest's Avatar
pacnorwest
Good info there Larry.
I checked with a buddy of mine - he's got the identical rig and supplemental braking system that I have (2015 SD diesel).
He spliced into the "violet-white" wire behind the brake pedal and installed a diode in-line with his supplemental wire.
He says it works.
However. . .
I'm thinking that your Blue-Orange wire is the way to go. . .probably easier if it can be accessed at the trailer plug at the rear of the vehicle.
Here's what I found so far:
#1 is off the brake pedal. #2 looks to be near the trailer wiring harness.
I will look into using #2 if I can find it.
Old Jun 18, 2015 | 05:56 PM
pacnorwest's Avatar
pacnorwest
I think that I found a blunt cut near the rear trailer plug.
The picture is upside down so that you can read the factory tag.
Looks like a point to tap into the brake light system.
I will know more tomorrow when I do the testing.
Old Jun 20, 2015 | 06:57 PM
pacnorwest's Avatar
pacnorwest
Yeah, the blue wire is from the center high stop light - but it's too far to run a wire back to the dash.
Instead, I tapped into the center high stop light inside the cab.
maddmatt02
Dec 4, 2017 08:00 AM
Sloppi
All Things Towing
Oct 22, 2012 09:06 PM
78REDFORD
Apr 23, 2008 10:06 AM
dwilliamsceg
Jan 4, 2007 06:56 AM
fordjockey
Jun 7, 2006 01:22 PM
