89 f150 running problem
Old Jun 15, 2015 | 03:20 PM
Ti3one's Avatar
Ti3one
Hi all,
I've ran in to a problem. First off about the truck. It's a 1989 f150 with the 4.2 duel tank setup. Fuel gauges don't work but that's a fix for later. The problem I'm having around 80 miles after filling the rear tank the gauge starts to work and then the truck starts to act like its out of gas. Yesterday after I filled it, it just shut off on me after maybe a few miles. I was thinking it was maybe the sending unit. But not 100% sure now
Old Jun 15, 2015 | 04:37 PM
rla2005's Avatar
rla2005
1998 or a 1989? I assume the former since the OBS style trucks did not come with a 4.2L engine.
Old Jun 15, 2015 | 04:41 PM
Ti3one's Avatar
Ti3one
89 sorry typo
Old Jun 15, 2015 | 06:12 PM
91custom's Avatar
91custom
'89 would have been a 4.9L I6. Either way, it may be fuel pump issue or even a vapor lock. It wouldn't hurt to get a fuel pressure reading.
Does it fire right back up? Was it just the one time? The sender issue itself is probably unrelated.
Old Jun 15, 2015 | 06:25 PM
Ti3one's Avatar
Ti3one
Yeah I think he sender is another problem. I'm going to get some fuel pressure reading tomorrow. Only does it when it's hot, after it cools down it fires right back up
Old Jun 15, 2015 | 06:40 PM
91custom's Avatar
91custom
That can be indicative of a vapor lock but fuel pumps can do some funky things at times too.
Old Jun 15, 2015 | 07:37 PM
rla2005's Avatar
rla2005
Very rare for a fuel injected engine to vapor lock. That said, Ford did install a cooling fan on the fuel rail on many of these 4.9L engines. I suggest to check the fuel pressure as well as determine if you are losing spark. Could also be as simple as the connector on the rear tank is making bad connection. Does the truck run on the front tank?
Old Jun 15, 2015 | 07:43 PM
91custom's Avatar
91custom
I've never personally worked on one that vapor locked but what he is describing sounds kind of like how I've heard it described. I've heard ethanol fuel can cause this but have no idea if that is correct or not. something about fuel being more volatile and building pressure in the fuel rail.
Old Jun 15, 2015 | 08:07 PM
rla2005's Avatar
rla2005
Urban myth
Old Jun 15, 2015 | 08:43 PM
Ti3one's Avatar
Ti3one
When I did use the front tank yes it ran, but don't use that one I need a new fill hose for it and haven't really had a need for it
Old Jun 17, 2015 | 02:17 PM
91custom's Avatar
91custom
If it runs on one tank and not the other, I would say it's likely the fuel pump.
Old Jun 17, 2015 | 02:27 PM
rla2005's Avatar
rla2005
Or the Dual function Reservoir is bad and the rear tank is filling the front. Does the front tank appear to be full even though you have not filled it? Common problem and can cause running issues.
f150man7933
May 5, 2014 09:15 PM
DBANDGB
May 14, 2011 06:58 AM
Saxon
Electrical Systems/Wiring
Jun 10, 2009 09:14 AM
