FUEL GAUGE
Old May 13, 2011 | 06:30 PM
DBANDGB's Avatar
DBANDGB
FUEL GAUGE
89 F-150 WITH TWO TANKS. UP UNTIL two weeks ago the tanks & gauges worked correct. now when i turn on the back tank the gauge goes past full & i know it is only about a 1/4 full. any guess to the problem. thanks
Old May 13, 2011 | 07:41 PM
andym's Avatar
andym
Open (or shorted) circuit to real fuel tank float sensor.
Old May 13, 2011 | 08:51 PM
ostrx250's Avatar
ostrx250
or the float went bad and sank
Old May 13, 2011 | 09:30 PM
BIGskinny's Avatar
BIGskinny
I'm having the same problem in my rear tank. Pumps bad but before that it just pegged over full when switched over. So I pulled m buddy's new pump and sending unit out in the process of swapping as I type. If still off. Were would I check at? I'm lost on fuel systems
Old May 14, 2011 | 06:58 AM
congo_abrezio's Avatar
congo_abrezio
im having the same problem with my rear tank.
im keen to see how you go..
ive got a new pump/sending unit for both tanks coming in the mail...
