Info on coolant system.
Old Jul 29, 2003 | 06:06 PM
Bsambear's Avatar
Bsambear
Question Info on coolant system.
Which coolant bought other than at Ford is suitable for the 2000 7.3L? Is there a coolant supplement available other than FW-16?
Old Jul 29, 2003 | 07:58 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Any plain ole' non extended life antifreeze will be fine.
I believe the non Ford version is called DCA-4, but it's the same stuff.
Old Jul 29, 2003 | 08:26 PM
rickeybell's Avatar
rickeybell
What is a coolant supplement??
Old Jul 29, 2003 | 09:14 PM
johnsdiesel's Avatar
johnsdiesel
The coolant additive is to prevent cavitation. If you don't use it, the coolant could gradually eat away parts of your engine.
Old Jul 29, 2003 | 10:24 PM
citro's Avatar
citro
Hi
how do you know when to add the coolant additive or is it just every so many miles?
citro
Old Jul 29, 2003 | 10:54 PM
mueckster's Avatar
mueckster
Ford recommends to add about 8 oz of coolant additive every 15,000 miles. You can also test the concentration with test strips designed for this purpose. In another forum, it was stated they got their strips @ $16 for 50 from Navistar. I get mine from work ( I service a fleet of diesel trucks), so I do'nt know of any better deals on test strips at this time. As for additive, I use WixCool from my local auto parts store.
Old Jul 29, 2003 | 11:06 PM
Motoxman_117's Avatar
Motoxman_117
Look into evans waterless cooling. Do a search and read up on it. Never have to use additives. I have been using it for quite awhile now in 100+ deg weather and no problems. check it out.
MotoX
Old Jul 30, 2003 | 07:05 AM
powerstroker250's Avatar
powerstroker250
Ford says not to use extended life coolants.
Old Jul 30, 2003 | 06:02 PM
Motoxman_117
Isnt premium gold extended life engine coolant? Just asking cause i dont know!
MotoX
Old Jul 30, 2003 | 08:20 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yes.
Old Jul 30, 2003 | 08:57 PM
RRMike's Avatar
RRMike
Old Jul 30, 2003 | 10:09 PM
Motoxman_117
powerstroker250 said that
So if premium gold IS extended life like cookie said yes too than why is ford putting it in at the factory? This isnt making any sense to me or maybe i misunderstood the contents of this thread.
MotoX
Old Jul 30, 2003 | 10:52 PM
cookie88's Avatar
cookie88
FTE Emeritus
Ok. The PSD's up to and including the 2001 model's have regular old antifreeze in them. Our owners manuals tell us not to use the ELC.
Starting sometime in the 02 model year Ford switched to the extended life coolant, so you guys with the newer trucks have the gold stuff.
I run the Evans, so I'm done with maintaining SCA's and coolant changes.........forever.
Old Jul 30, 2003 | 10:56 PM
Motoxman_117
I am running evans too but i just wanted to clarify the posts. How much evans did it take to fill your rig cookie?
MotoX
Old Jul 31, 2003 | 03:59 AM
cookie88's Avatar
cookie88
FTE Emeritus
Just a hair under 7 gallons.
