Info on coolant system.
Old Jul 31, 2003 | 07:31 AM
powerstroker250's Avatar
powerstroker250
Originally posted by cookie88
Ok. The PSD's up to and including the 2001 model's have regular old antifreeze in them. Our owners manuals tell us not to use the ELC.
Starting sometime in the 02 model year Ford switched to the extended life coolant, so you guys with the newer trucks have the gold stuff
That is correct. Just remember the plain old stuff has the be LOW silicate.
Old Aug 4, 2003 | 10:36 PM
citro's Avatar
citro
cookie
What changes are needed to run the Evans coolant. Sounds like the way to go.
I looked at there website and I see you can purchase from them is this how you got the best price?
Does it take longer for warm ups? I ask this cause it can get real cold up here in Minnesota!
thanks
citro
Old Aug 4, 2003 | 10:54 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
citro
There are no changes neccessary to run Evans. Just completely drain the old stuff (radiator, block, heater core, everything) and refill with the Evans.
Since I had it apart anyways I also switched to the 203* thermostat and added a coolant filter.
Warmups......I'll assume that you plug it in when it's that cold, but if you can't, warmup time should be about the same, or possibly a litle quicker since Evans dosen't freeze.
Old Aug 4, 2003 | 11:08 PM
Motoxman_117's Avatar
Motoxman_117
I had to drill a hole in my radiator cap since it is a pressureless system which is one of the benefits.
MotoX
Old Aug 4, 2003 | 11:21 PM
citro's Avatar
citro
MOTOXMAN
Why did you drill a hole in the cap? Is this required by Evans?
What would be the reason for the themostate change?
Where did you get your Evanes coolant?
thanks
citro
Old Aug 5, 2003 | 12:55 AM
macwalnut's Avatar
macwalnut
I talked to the International dealer, he told me they have been putting ELC in all there trucks, and you don't have to worry with the additive. I have a 2000 PSD, so I put the Fleetrite Extended in mine @ 40,000
Old Aug 5, 2003 | 04:02 AM
cookie88's Avatar
cookie88
FTE Emeritus
It's not required, but since there is no water in Evans there is no pressure in the system. I also drilled a hole in mine, but forgot to mention it. The purpose is to let any little bit of water that is left in the system after the change boil out of the system.
The hotter you can safely run a diesel, the more efficient it will be. Raising the temp of the thermostat allows the engine to run closer to International's spec's.
Old Aug 5, 2003 | 06:01 PM
Motoxman_117
You have to drill a hole in the cap to make it a pressureless system. Stock cooling systems are pressurized to bring the boiling point temperature up of the 50/50 stock coolant setup. The evans has a very high boiling point without being put under pressure. By releasing the pressure you are taking most of the strain off of the coolant system i.e. hoses and waterpump and seals. Evans coolant is great for the cavitation problem in engines which is when the 50/50 mix turns into bubbles or steam when contacting hot surfaces and the bubles then beat on your cylinder walls and creates pin holes in the outer part of the cyl liners. The evans doesnt have water so it has better heat transfer and doesnt steam off. People are putting a higher temp thermostat in because the diesel runs more efficient at a slightly higher temp. I didnt go to a higher temp thermostat as part of the tranny cooler oil on the powerstroke goes through radiator to transfer heat. I didnt want that heat from the higher thermostat to heat my tranny oil any more than stock. Hpoe this helps. I explained it the easiest way i could.
MotoX
Old Aug 5, 2003 | 10:35 PM
citro's Avatar
citro
Thanks for the help guys
I will order my Evans coolant in the morning
citro
Old Aug 6, 2003 | 07:42 PM
Motoxman_117
one word of advice would be to read the instuctions on purging the old stuff out and to make sure you get it all. Do not deviate from there instuctions because you do not want to mix the evans with the old coolant. Mine took about 5.75 gallons of evans eventhough diesel site too says 8 gallons. order 8 so you can drain some later and then re add the rest to insure you get the most evans in and the old coolant out. Hope this helps.
MotoX
Old Aug 9, 2003 | 10:28 AM
Motoxman_117
If you have any other questions about it let me know. Tell us how much it took to fill your rig when you are done.
MotoX
Old Aug 9, 2003 | 10:11 PM
citro's Avatar
citro
I should have my coolant in 4-5 days, will let you know how much I get in.
Thanks
citro
Old Aug 20, 2003 | 10:49 AM
  #28
PSDLOVER's Avatar
PSDLOVER
I bought a 02 PSD CC 4x4 F-250 a couple months ago with 30K on it. I wanted to make sure everything was as it should be before hauling my 31 ft fifth wheel into the Rockies this summer. So I discussed maintainenc requirements with the local ford dealers parts guy who told me I needed to use the coolant additive which I purchased and added the entire 16 ounce bottle as he recommended. Now, I've learned that I do not need it with the gold coolant! Will it do any damage to my system?
Old Sep 6, 2003 | 11:47 PM
  #29
citro's Avatar
citro
HI guys
Got my Evans coolant in.
I followed all the instructions with the draining.
It took 6 and 1/2 gallons of the Evans coolant.
After about 200 miles I sent a sample into Evans testing.
The guy there called and said I had 10 percent water and needed to drain and add rest of the Evans coolant to get it down to 3.5 percent or less, then send in a new sample.
My question is. Did any of you have this problem?
Did you take the presure spring out of your radiator cap?
Mine fell out when I drilled the small hole in it, then it would not stay in so I left it out. Will that be OK?
Also, I get the smell of hot antifreeze after running the truck will that go away?
Thanks
Citro
ps here is a good laugh
After draining the radiator, I put a nice big pan to catch the old coolant from the engine block. (Not realizing the force the coolant would come out of the engine plugs.) Needless to say, it sprayed all over my face,hair and chest. Sending me to the shower and spitting for about 2 hours to get the tast out of my mouth. Good thing I was wearing my safty glasses!
Old Oct 26, 2003 | 08:17 PM
  #30
Andywk's Avatar
Andywk
I am thinking about ordering the Evans waterless coolant in the next couple of days and would like to add that it would probaly be a good idea to change the upper radiator hose at this time to the dual alternator style hose so that it does not go through the belt. Would this be correct in assuming this?
john guard
1983 - 2012 Ranger & B-Series
21
Jul 24, 2025 11:52 PM
lude98r
May 1, 2012 09:45 PM
powerstrokedieselfan
Dec 26, 2010 11:44 AM
2kstroker
Oct 31, 2005 06:37 PM
ehagerty
Sep 9, 2003 07:56 AM
