Sponsored by: Real Truck
no power
Old Jun 13, 2015 | 08:14 AM
love my truck's Avatar
love my truck
no power
After clearing the light on dash the truck runs good. Then when truck worms up it starts running rough with no power when i give it gas. Very sluggish does not want to go. Replaced coils did not help, replaced VCT Solenoid not that Please help! Thinking it could be a o2 censer?
Old Jun 13, 2015 | 12:37 PM
projectSHO89's Avatar
projectSHO89
No.
Take the truck to a shop or dealer where someone who knows what they're doing can diagnose it.
Old Jun 13, 2015 | 01:20 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Any chance you got the codes before you cleared them? When you get a CEL, find out what it is. That way we have a direction to go.
Also, what can you tell us about your truck?
I assume it's a gas since you said you changed the coils.
What motor?
Year?
Standard or automatic transmission?
2 or 4 wheel drive?
How many miles are on it?
Have you done any modifications to it?
Old Jun 14, 2015 | 07:05 AM
love my truck
no power
Thanks CampSpringsJohn for your reply
My truck is a 2005 f-250 with a 5.4 gas engine. With a automatic transmission,
4 wheel drive with 150,000 miles. The code reader said that 1 and 2 cylinders misfiring and bank one was running to lean. I bought the truck one year ago I change the coils on 1,2,3 and 4 cylinders, I thinking the plugs have never been change. what do you think start with plugs or o2 censer?
Old Jun 14, 2015 | 07:18 AM
Tom's Avatar
Tom
Stop throwing parts at the problem, you're only certain to drain your wallet and fix the problem if you get lucky.
Sounds like something isn't right when the PCM switches to closed loop after it warms up. It's possible that the oxygen sensor is causing a mixture problem, but impossible to determine without more testing. What are your fuel trims?
Check out this article, it breaks down lots of possible causes: Ford P0171 & P0174 Lean Codes
tjc transport
6.2L V8
24
Feb 6, 2017 07:45 AM
francissmith14
Modular V8 (4.6L, 5.4L)
Sep 27, 2014 07:45 AM
kalpesh
16
Dec 9, 2011 09:30 PM
soulssong
1983 - 2012 Ranger & B-Series
Oct 25, 2008 11:25 PM
anfo
Jan 4, 2008 02:13 PM
