The term "big block" may also be applicable to the 429/460 engines.
"Big block" is kind of a misnomer with regards to the FE since the same block could have displacements of 330, 352, 360, 390, 410, or even 428... it was a matter of changing the stroke and bore but using the same block.
... the FE follows the same principle as Pontiac 389s, 400s, and 455s. Looks the same on the outside but dimensionally different on the inside.
