Disassembling I-beams Stuck Bolt.
Old Jun 7, 2015 | 09:33 PM
Lug Nut's Avatar
Lug Nut
Bathed it in PB Blaster if that helps.
I'm taking in the process of disassembling the I-beams on my 69 F250 and bolt that connects the radius arm to the I-beam on the right side seems frozen in place. I've taken off the coil spring and cup and the two nuts but the bolt wont budge. The impact gun does nothing. I didn't want to apply heat to it but right now I can't think of anything else unless I'm overlooking something really simple. It should turn freely right? Thanks.
Old Jun 7, 2015 | 09:40 PM
HIO Silver's Avatar
HIO Silver
Jack the I-beam level and apply the impact gun from underneath?
Or put a wood block over the threaded end and wack it with a maul or substantial ballpeen.
Old Jun 7, 2015 | 09:44 PM
Early 1969's Avatar
Early 1969
Mine didn't come off that hard. If it were mine i'd run that nut down flush with the bolt then give it a couple love taps with the bfh. If you don't have an oxy-acetylene torch, then even a propane torch should help a little. Good luck!
Old Jun 7, 2015 | 10:51 PM
Lug Nut's Avatar
Lug Nut
Thanks guys but I have tried all those things. I hit it harder than I should have with a sledge that is bigger than I should be using for a bolt I don't want to damage. I tried the impact gun and even a breaker bar with a 4+ foot cheater pipe on it. bent the breaker bar but no joy. I do have oxy acetylene but I didn't like the idea of putting heat to a forged piece. Having said that I've decided to replace these I-beams anyway and have ordered new ones from Autofab. I still need this bolt and radius arm though so tomorrow it gets the torch. I can take the assembly to the press to so I'll try that too.
Old Jun 8, 2015 | 12:51 AM
Cracker289's Avatar
Cracker289
I was about to say a man with a cheater bar is 10 times stronger than an impact gun, but then I read that used a 4 foot cheater and bent that! Wow, that is tough! I know this might sound stupid, but have you tried TIGHTENING it? I have found, sometimes, on a stuck bolt if I can force it in a teeny bit tighter it then lets me loosen it. Just a thought and I don't want to be responsible if that makes it worse
Old Jun 8, 2015 | 09:47 AM
TeachNlive4ever's Avatar
TeachNlive4ever
Ditto on what the Cracker said. I do that very thing with all my line nuts so I won't round them off.
Good luck and lets us know the final out come.
Old Jun 8, 2015 | 10:34 AM
orich's Avatar
orich
I'd hit it after applying a good amount of heat.
If your a welder you should know about how much heat to put on it.
It's not like your going to be heating it up to do any welding on it. Right.
Orich
Old Jun 8, 2015 | 10:50 AM
68fish's Avatar
68fish
Beat it up. The price of a new bolt has to be WAY less than the price of a new I beam or Radius Rod.
Old Jun 8, 2015 | 11:01 AM
qman's Avatar
qman
n/m, dumb suggestion
Old Jun 8, 2015 | 04:34 PM
Lug Nut's Avatar
Lug Nut
Heat, Hammering and cursing did the trick. I didn't get it that hot and only used a plumbers torch and not the oxy rig. The other side came right apart.
now on to the fun stuff.
Old Jun 8, 2015 | 06:40 PM
ultraranger's Avatar
ultraranger
Anti-Seize the bolt shank and threads, before you reassemble.
Old Jun 9, 2015 | 10:55 AM
qman's Avatar
qman
You were supposed to curse the first time. Let that be a lesson to you.
Zeitgeist57
Feb 3, 2014 12:10 AM
86fordtruck
Jan 1, 2012 04:29 PM
rpxr400
2004 - 2008 F150
Oct 20, 2008 12:19 PM
the kid
Oct 26, 2006 05:09 PM
cptbfp
Garage & Workshop
Oct 25, 2005 11:26 AM
