Ac compressor not turning on.
Old Jun 7, 2015 | 08:12 PM
Peavey1986's Avatar
Peavey1986
We'll I just put a new motor in my 86 f150. It has factory ac and worked perfict till I changed the motor. Now the compressor is not kicking on. Everything I see is plugged in and the system is full of refrigerant . What should I check first? Is a fuse in line some place?
Old Jun 7, 2015 | 08:33 PM
ctubutis's Avatar
ctubutis
I would probably put a voltmeter on the compressor's signal connection and see if voltage is making its way to the compress or not.
I'm guessing this is the original compressor off the old engine?
Old Jun 7, 2015 | 08:36 PM
Peavey1986's Avatar
Peavey1986
Yes it is the original compressor . And if there is no 12 volts going to the compressor then what? What sends power to the compressor?
Old Jun 7, 2015 | 09:40 PM
ctubutis's Avatar
ctubutis
The following is from my 1981 EVTM, AFAIK it applies to your 1986 model, too; see if this stuff helps you:
Old Jun 8, 2015 | 02:38 PM
Franklin2's Avatar
Franklin2
99% of the time the system is low on refrigerant. Go in and turn the A/C on, and the fan on high. Go out to the large accumulator can, usually on it or around it is the low pressure switch. Unplug the switch and jump the wires in the plug with a short piece of wire. If the compressor kicks on, you are most likely low on refrigerant.
Old Jun 8, 2015 | 09:25 PM
bruno2's Avatar
bruno2
Dave has suggested the quickest and cheapest way to determine if you are low on refrigerant.
Gibby55
Mar 25, 2017 07:15 PM
TheKirbyMan
Sep 18, 2010 10:01 PM
octaneforce
Mar 22, 2009 01:49 PM
HOEO
Jan 14, 2007 09:07 PM
Alby
Apr 5, 2005 09:53 PM
