problem with 2001 4.6 (e150)
Old Jun 5, 2015 | 05:29 PM
richrd's Avatar
richrd
7th Gear
I posted this up above before I found this board so hope you don't mind me copying it here.
my work van has been running poorly so after much procrastination, I put in four new coil packs and two plugs. ( that was all the self abuse I could stand for one session).
So now, it it will start and idle fine but no low end power to drive. it idles for a short time then shuts off. Restart and it will shut off in less time.
At first there was surging which made me look for vacuum leaks but found none.
when I turn the key on, the rail pressure pumps up then bleeds down slightly.
when running it shows 40 pounds of pressure right up until it shuts off.
I hate working on vans but really don't want to buy another work truck.
Any advice?
thanks
Old Jun 12, 2015 | 06:49 AM
JWA's Avatar
JWA
You have an OBD-II system that should be interrogated for whatever DTC's might be present. From there it should be much more simple than just changing parts without any real direction or clue what problems actually exist.
Post any DTC's and help should be forthcoming.
Old Jun 12, 2015 | 07:15 AM
richrd's Avatar
richrd
7th Gear
all obie said was misfire detected cylinder two. not a of of help
Old Jun 14, 2015 | 07:26 AM
JWA's Avatar
JWA
Not a misfire on #2 only as a DTC ain't helpful.
Fuel pressure---while running does it remain steady up until it shuts off OR does it suddenly drop then shut down?
I'm curious if the fuel pressure regulator isn't involved with all this?
Old Jun 14, 2015 | 05:48 PM
richrd's Avatar
richrd
7th Gear
the pressure remains constant until the shutoff. I thought about the regulator, but I was no where near it while working and the vacuum line is intact. (I'm a motorcycle mech, but I hate working on anything with four wheels)
Old Jun 16, 2015 | 06:42 AM
JWA's Avatar
JWA
Just because connections to the FPR seem intact doesn't mean it hasn't failed.
I'm still concerned or a bit shocked more DTC's are shown--but that's another issue I'm sure.
richrd
1997 - 2003 F150
Jun 5, 2015 05:23 PM
hoss khaos
Modular V8 (4.6L, 5.4L)
Oct 15, 2011 10:12 PM
bff
1983 - 2012 Ranger & B-Series
Jun 23, 2009 10:22 AM
4x4Junky
Sep 10, 2007 11:05 AM
H_E_R_N
1997 - 2003 F150
18
Mar 15, 2004 02:20 PM
