Cab/engine bay electrical for towing
Old Jun 3, 2015 | 02:00 PM
Tractor Tyler's Avatar
Tractor Tyler
Hello does any one have wiring diagrams for a 94 ford f350 5.8 with out the towing package? It appears as the wiring ends at the fire wall and not the rear section of the frame I would like to use the Factory fuses and run wire from the fuse box to the 7 pin plug also for the signal/brake lights there is wires to the under the hood fuse box but I can get any power to them any input would be awesome
Thanks Ty
Old Jun 3, 2015 | 02:30 PM
jerryparks's Avatar
jerryparks
Okay, so you need 3 fuses. A 30A self-resetting fuse, a 20A self-resetting fuse. The 30A is for the brake controller, the 20A is for the AUX power.
There's a way to add a fuse to the ground to prevent a short in the trailer from tripping a truck fuse, but you can also add a fuse to each line.
Leemakesmepee
Nov 24, 2012 04:44 PM
wuttrd
May 16, 2012 05:47 PM
BMWBig6
2009 - 2014 F150
Jan 13, 2012 04:48 AM
No-Tyme
Electrical Systems/Wiring
Apr 20, 2010 08:27 AM
beachrat
Apr 30, 2008 07:16 PM
