need a point for power for strob install
Old Jul 19, 2009 | 11:46 AM
No-Tyme's Avatar
No-Tyme
I am installing a set of 4 strobes ans maybe in the future an overhead. But for now I want to run the 4 strobes (LED Code 3) that pull .6 amps each and I am looking for a point of orgin for power. I have look over the fuse box and don't see anything that I can tap into.
I haven't even started looking for a point to run the wires out of the cab, but I am making all the connections just below the driver seat.
Anyone have any ideas???
Old Jul 19, 2009 | 04:27 PM
Franklin2's Avatar
Franklin2
You can buy fuse taps at the store to tap into the fuse box. They slip under the fuses you already have. If you are worried about overloading the fuse in the fuse box, you can put the tap on the incoming side of the fuse and then use a external inline fuse to protect the new wire. Just pick a fuse source that works the way you want, ie current with the key in run only or current all the time from the battery.
If you run any thing with a larger load, you can think about running a relay for more power, but those loads you are talking about should be alright directly out of the factory fuse box.
Old Jul 29, 2009 | 12:58 PM
okgearhead's Avatar
okgearhead
If you have a tow package, there is a brake controller hook-up under your dash with a 12 volt source. Thats where I hooked-up my volt gauge.
Old Apr 20, 2010 | 08:27 AM
No-Tyme's Avatar
No-Tyme
follow up
The fuse taps worked out great!
