Codes clear themselves?
Old Jul 29, 2003 | 09:36 AM
satcomjimmy's Avatar
satcomjimmy
I have been having issues with my tranny, just had fluids flushed and wanted to see if it helps the problem. It was showing incorrect gear ratio after 3rd gear was commanded (647 I think). I asked the shop to clear the codes so OD Off would stop flashing, so I could see if it came back. They said it will basically clear itself if the fluid change solved the problem, and it would be best to leave it as it is for a while. How does this work and is this correct information? Will good self-diagnostics clear trouble conditions by itself?
Old Jul 29, 2003 | 11:03 AM
Blue96
Guest
Posts: n/a
Try disconnecting battery. I know check engine light is reset by disconnecting battery for a minute or so. I don't know if the same applies to the codes?
jonrjen
6.7L Power Stroke Diesel
Nov 7, 2013 08:03 PM
Two000F250
Oct 6, 2013 12:10 PM
elskeptico
Apr 21, 2012 03:14 PM
busflyer
Jan 24, 2012 09:56 PM
tubolove
Feb 1, 2009 04:25 PM
