Bronco II Ford Bronco II
88 cooling problem
Old Jun 1, 2015 | 04:24 PM
phantomphixer's Avatar
phantomphixer
88 cooling problem
Had a cooling problem on 88 Bronco I bought a few weeks ago.
During checks I made I discovered fan belts out of whack. On closer inspection the water pump pulleys were out of alignment by over 3/4". Decided to pull water pump, upon removal discovered the impeller laying in the engine cavity opening. It had worn the back of the water pump into a razor sharp edge. Amazing that it didn't leak.
Just something to be aware of on these little motors.
Old Jun 2, 2015 | 12:29 AM
87 XLT's Avatar
87 XLT
Thanks for the heads up on that.
Another thing that can be hard to figure out is when the impeller breaks loose & the shaft just spins inside it.
Old Jun 13, 2015 | 10:43 PM
Blindtoe's Avatar
Blindtoe
I found a all Aluminum radiator 3 row on Ebay Bolts right in easy to replace. Look for 1988 ford bronco11. Good Luck
Old Jun 14, 2015 | 07:37 PM
HappyJack's Avatar
HappyJack
3 core Aluminum? In 88? Thought all 2.9 stock radiators were 1 core. I run a 2 core Aluminum 4.0 radiator in my 88. Only 3 core Bronco II radiator I saw was a brass 2.8 radiator. It uses a different core support and will not bolt to the aluminum radiator support. Do you have a link or manufacture of this radiator?
RalphXL
Mar 15, 2019 09:17 PM
big ole ford
Aug 16, 2018 07:42 PM
anthonym92
Jan 11, 2017 12:22 AM
bobbywillis
Bronco II
Aug 1, 2008 10:58 PM
GeneStoner
Jan 20, 2003 07:49 AM
