Power Steering Fluid Check
Old Jun 1, 2015 | 12:05 PM
Chevmn56's Avatar
Chevmn56
Hello All, I have a question about checking the power steering fluid......maybe i'm old school!!!! i used to always check the power steering fluid while the motor was running. I just changed the fluid and put in a new pump......so for giggles i read the manual on that, and it says to check it while the motor is off WTF!!!!! and it says too check the cold side of the dipstick. i always thought the cold side was for when you first started the motor and the hot side was for when the motor was up to temp, the manual says nothing about the hot side of the dipstick.
So if any of you gurus out there can shed some light i sure would like to know what is the correct way to check this fluid........Hot and Cold cold side of the dipstick
Thanks
Old Jun 1, 2015 | 03:11 PM
BillyBob69's Avatar
BillyBob69
I always checked mine with the engine off. Engine on and up to temp for the tranny.
Other then that...If you put in a new OEM pump...make sure you use tranny fluid in it, not PS fluid.
Old Jun 1, 2015 | 03:26 PM
Chevmn56's Avatar
Chevmn56
Oh sh@# senior moment your right.... So the hot side on the dipstick would be if its been running and the cold side would be when it hasnt been running.?
Thanks
Budman1962
Jul 29, 2013 06:26 PM
jcgc50
Jun 24, 2010 01:12 PM
61 uni
Aug 17, 2009 10:50 PM
UGA33
Aug 8, 2008 11:51 PM
woods
Jun 22, 2005 02:52 PM
